- To:
- Subject: Re: [cgal-discuss] Triangulation: point is not inserted
- Date: Mon, 29 Jun 2009 16:49:41 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=EVgx2nkoWDgsF06meVk3mqCT2zNVjFIaWtvnZhWJH5L7P+ND3qxgYYYQ1GTpy+Jvza UCyFpWvZnUH72TEzL7uQf0acNXWQTdTyOHBOwHOVf/0NE6LGwaErIeIIcS8hI+WZ33z5 mPh3Ai3ooc5vjMPJ8AF4GV9r343R5vPnnC9Cs=
Hi Frank,
CGAL will reject a point that is coincident with an existing point in the triangulation; very desirable behavior in my opinion.
Regards,
Damian
On Mon, Jun 29, 2009 at 2:42 PM, gtsml owevwr <> wrote:
Hi,
I'm using a Delaunay triangulation and some of the points are not
inserted: the number of vertices in the triangulation is the same
before and after the insertion. Is it done on purpose so that similar
points cannot be added twice?
Thanks,
Frank
- [cgal-discuss] Triangulation: point is not inserted, gtsml owevwr, 06/29/2009
- Re: [cgal-discuss] Triangulation: point is not inserted, Sylvain Pion, 06/29/2009
- Re: [cgal-discuss] Triangulation: point is not inserted, Damian Sheehy, 06/29/2009
- Re: [cgal-discuss] Triangulation: point is not inserted, gtsml owevwr, 06/30/2009
- Re: [cgal-discuss] Triangulation: point is not inserted, Daniel Duque, 06/30/2009
- Re: [cgal-discuss] Triangulation: point is not inserted, Andreas Fabri, 06/30/2009
- Re: [cgal-discuss] Triangulation: point is not inserted, Camille Wormser, 06/30/2009
