- To:
- Subject: Re: [cgal-discuss] Triangulation: point is not inserted
- Date: Tue, 30 Jun 2009 11:28:49 +0200
Note that you can detect this by performing a locate first, check the Locate_type
and then insert if necessary. This is not slower than just inserting.
You should mention that the result of the locate call should be provided as a hint to the insert method (for the performance to be maintained).
Camille
- [cgal-discuss] Triangulation: point is not inserted, gtsml owevwr, 06/29/2009
- Re: [cgal-discuss] Triangulation: point is not inserted, Sylvain Pion, 06/29/2009
- Re: [cgal-discuss] Triangulation: point is not inserted, Damian Sheehy, 06/29/2009
- Re: [cgal-discuss] Triangulation: point is not inserted, gtsml owevwr, 06/30/2009
- Re: [cgal-discuss] Triangulation: point is not inserted, Daniel Duque, 06/30/2009
- Re: [cgal-discuss] Triangulation: point is not inserted, Andreas Fabri, 06/30/2009
- Re: [cgal-discuss] Triangulation: point is not inserted, Camille Wormser, 06/30/2009
