cgal-discuss - Re: [cgal-discuss] Triangulation: point is not inserted
  • To:
  • Subject: Re: [cgal-discuss] Triangulation: point is not inserted
  • Date: Tue, 30 Jun 2009 09:56:49 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=LWGB9yaVJYVMif6nQ977WmrF1ic8RPi+xw4hY0BQq3Fr6PLMt5M0FwLytNae+3p6By RznZaFM11lFgOs8O7zqxN6JZe5Bzns5cH8vvxYUy4G7osj9E8EvH25+vvmRRzZrVPJau rFknWN5h/MfargdzI6Be/oXzVv8jWk4eHeZ7o=
Thanks for your answers,
I agree, it is desirable, but I also have to admit it that not being
aware of it have cost me 4 hours of desperate debugging :-(
Thanks
Frank
PS: As a side note, this behavior would have been more obvious if it
was contained in the API itself, ala std::set for instance where the
insert function returns a std::pair. But of course, such design make
the API less readable.
On Mon, Jun 29, 2009 at 9:49 PM, Damian
Sheehy<>
wrote:
> Hi Frank,
> CGAL will reject a point that is coincident with an existing point in the
> triangulation; very desirable behavior in my opinion.
> Regards,
> Damian
> On Mon, Jun 29, 2009 at 2:42 PM, gtsml owevwr
> wrote:
>> Hi,
>> I'm using a Delaunay triangulation and some of the points are not
>> inserted: the number of vertices in the triangulation is the same
>> before and after the insertion. Is it done on purpose so that similar
>> points cannot be added twice?
>> Thanks,
>> Frank
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://lists-sop.inria.fr/wws/info/cgal-discuss
