cgal-discuss - Re: [cgal-discuss] Problems when installing taucs_full
  • To:
  • Subject: Re: [cgal-discuss] Problems when installing taucs_full
  • Date: Fri, 10 Jul 2009 10:30:08 +0200
Hi,
Which version of gcc do you use (cc -v)?
Laurent Saboret
INRIA Sophia-Antipolis
sanlington a ??crit :
hi,
i downloaded taucs_full.tgz <http://gforge.inria.fr/frs/download.php/12636/taucs_full.tgz> from www.cgal.org, when i tried to install it,some errors occured:
[root@sanlington
taucs_full]# ./configure
cc -o configurator/configurator configurator/taucs_config.c
[root@sanlington
taucs_full]# make
mkdir obj
mkdir obj/linux/
echo exists > obj/linux/exists.log
cc -c -O3 -Wall -std=c99 -DMACHTYPE_ -I src/ -I build/linux/ -I external/src/ \
progs/taucs_blas_underscore_test.c \
-o ./obj/linux/taucs_blas_underscore_test.o
cc \
-o ./obj/linux/taucs_blas_underscore_test \
obj/linux/taucs_blas_underscore_test.o -L external/lib/linux -llapack -L external/lib/linux -lf77blas -lcblas -latlas -L external/lib/linux -lmetis -lg2c -lm
obj/linux/taucs_blas_underscore_test build/linux/taucs_config_tests.h
obj/linux/taucs_blas_underscore_test: error while loading shared libraries: libg2c.so.0: cannot open shared object file: No such file or directory
make: [build/linux/taucs_config_tests.h] Error 127 (ignored)
progs/taucs_blas_nounderscore_test.c \
-o ./obj/linux/taucs_blas_nounderscore_test.o
cc \
-o ./obj/linux/taucs_blas_nounderscore_test \
obj/linux/taucs_blas_nounderscore_test.o -L external/lib/linux -llapack -L external/lib/linux -lf77blas -lcblas -latlas -L external/lib/linux -lmetis -lg2c -lm
obj/linux/taucs_blas_nounderscore_test.o: In function `main':
taucs_blas_nounderscore_test.c:(.text+0xa4): undefined reference to `dgemm'
collect2: ld returned 1 exit status
make: [build/linux/taucs_config_tests.h] Error 1 (ignored)
obj/linux/taucs_blas_nounderscore_test build/linux/taucs_config_tests.h
make: obj/linux/taucs_blas_nounderscore_test: Command not found
progs/taucs_c99_complex_test.c \
-o ./obj/linux/taucs_c99_complex_test.o
cc \
-o ./obj/linux/taucs_c99_complex_test \
obj/linux/taucs_c99_complex_test.o -L external/lib/linux -llapack -L external/lib/linux -lf77blas -lcblas -latlas -L external/lib/linux -lmetis -lg2c -lm
obj/linux/taucs_c99_complex_test build/linux/taucs_config_tests.h
obj/linux/taucs_c99_complex_test: error while loading shared libraries: libg2c.so.0: cannot open shared object file: No such file or directory
progs/taucs_cilk_test.c \
-o ./obj/linux/taucs_cilk_test.o
progs/taucs_cilk_test.c:8:19: error: cilk.h: No such file or directory
progs/taucs_cilk_test.c:10: warning: ignoring #pragma lang
progs/taucs_cilk_test.c:12: error: expected ??=??, ??,??, ??;??, ??asm?? or ??__attribute__?? before ??int??
progs/taucs_cilk_test.c:17: error: expected ??=??, ??,??, ??;??, ??asm?? or ??__attribute__?? before ??int??
cc \
-o ./obj/linux/taucs_cilk_test \
obj/linux/taucs_cilk_test.o -L external/lib/linux -llapack -L external/lib/linux -lf77blas -lcblas -latlas -L external/lib/linux -lmetis -lg2c -lm
cc: obj/linux/taucs_cilk_test.o: No such file or directory
obj/linux/taucs_cilk_test build/linux/taucs_config_tests.h
make: obj/linux/taucs_cilk_test: Command not found
mkdir bin
mkdir: cannot create directory `bin': File exists
make: [bin/linux/exists.log] Error 1 (ignored)
mkdir bin/linux/
echo exists > bin/linux/exists.log
mkdir lib
mkdir: cannot create directory `lib': File exists
make: [lib/linux/exists.log] Error 1 (ignored)
mkdir lib/linux/
echo exists > lib/linux/exists.log
-DTAUCS_CORE_GENERAL \
src/taucs_sn_llt.c \
-o ./obj/linux/taucs_sn_llt.o
In file included from src/taucs_sn_llt.c:13:
src/taucs.h:6:32: error: taucs_config_tests.h: No such file or directory
src/taucs.h:79:2: error: #error "taucs_blas_[no]underscore_test: linking with the BLAS failed both attempts"
src/taucs.h:828: error: ??taucs_blas_name?? declared as function returning a function
src/taucs.h:828: warning: parameter names (without types) in function declaration
src/taucs.h:829: error: ??taucs_blas_name?? declared as function returning a function
src/taucs.h:829: warning: parameter names (without types) in function declaration
src/taucs.h:830: error: ??taucs_blas_name?? declared as function returning a function
src/taucs.h:830: warning: parameter names (without types) in function declaration
src/taucs.h:831: error: ??taucs_blas_name?? declared as function returning a function
src/taucs.h:831: warning: parameter names (without types) in function declaration
make: *** [obj/linux/taucs_sn_llt.o] Error 1
how to do next ?
200????????,????????,?????????? <http://count.mail.163.com/redirect/footer.htm?f=http://gouwu.youdao.com>
