- To:
- Subject: Re: [cgal-discuss] Problems when installing taucs_full
- Date: Tue, 14 Jul 2009 06:37:54 +0200 (CEST)
On Mon, 13 Jul 2009, Laurent Saboret wrote:
Hi sanlington,
I do not have gcc version 4.4 but I was able to reproduce the bug with gcc 4.3.
The first error occurs here:
obj/linux/taucs_blas_underscore_test build/linux/taucs_config_tests.h
obj/linux/taucs_blas_underscore_test: error while loading shared
libraries: libg2c.so.0: cannot open shared object file: No such file or
directory
You need the libg2c shared library, which is part of g77 Fortran compiler = GNU 3.x Fortran compiler.
You should install g77 (not gfortran = GNU 4.x Fortran compiler).
On my OS (Fedora 7), it comes for example in the compat-gcc-34-g77 rpm.
On a modern distro, you are better off not using g77 (or g2c) at all. For taucs, replacing g77 by gfortran and removing -lg2c in the config file and removing the precompiled libs (gfortran-compiled versions of which are provided by my distro) works fine.
Marc Glisse
- [cgal-discuss] Problems when installing taucs_full, sanlington, 07/10/2009
- Re: [cgal-discuss] Problems when installing taucs_full, Laurent Saboret, 07/10/2009
- Re:Re: [cgal-discuss] Problems when installing taucs_full, sanlington, 07/10/2009
- Re: [cgal-discuss] Problems when installing taucs_full, Laurent Saboret, 07/13/2009
- Re: [cgal-discuss] Problems when installing taucs_full, Marc Glisse, 07/14/2009
- Re: [cgal-discuss] Problems when installing taucs_full, Laurent Saboret, 07/15/2009
