- To:
- Subject: Re: [cgal-discuss] errors with Quotient.h and Object.h on windows
- Date: Thu, 06 Aug 2009 16:31:49 +0200
- Organization: INRIA
wrote:
hi,
please help.
I installed cgal-3.5.1-beta with windows installer, when I want to compile the
example "examples/Straight_skeleton_2/Create_offset_polygons_2.cpp" in
vc8,some strange error occurs as following:
It seems the <CGAL/config.h> which is found is not the correct one.
Can you double check that you are not taking one from CGAL-3.4 ?
(I'm not sure what the Windows installer does)
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
- [cgal-discuss] errors with Quotient.h and Object.h on windows, tong-zhiqiang, 08/06/2009
- Re: [cgal-discuss] errors with Quotient.h and Object.h on windows, Sylvain Pion, 08/06/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] errors with Quotient.h and Object.h on windows, 同治强, 08/06/2009
- Re: [cgal-discuss] errors with Quotient.h and Object.h on windows, tong, 08/07/2009
