- To: "cgal-discuss" <>, "cgal-discuss" <>
- Subject: Re: [cgal-discuss] errors with Quotient.h and Object.h on windows
- Date: Thu, 6 Aug 2009 22:36:19 +0800
<CGAL/config.h> is generated by the windows installer, and the same errors occur with CGAL-3.4
------------------ Original ------------------
Date: 2009年8月6日(星期四) 晚上10:31
To: "cgal-discuss"<>;
> hi,
> please help.
> I installed cgal-3.5.1-beta with windows installer, when I want to compile the
> example "examples/Straight_skeleton_2/Create_offset_polygons_2.cpp" in
> vc8,some strange error occurs as following:
It seems the <CGAL/config.h> which is found is not the correct one.
Can you double check that you are not taking one from CGAL-3.4 ?
(I'm not sure what the Windows installer does)
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
- [cgal-discuss] errors with Quotient.h and Object.h on windows, tong-zhiqiang, 08/06/2009
- Re: [cgal-discuss] errors with Quotient.h and Object.h on windows, Sylvain Pion, 08/06/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] errors with Quotient.h and Object.h on windows, 同治强, 08/06/2009
- Re: [cgal-discuss] errors with Quotient.h and Object.h on windows, tong, 08/07/2009
