cgal-discuss - Re: [cgal-discuss] triangulation face base with info
  • To:
  • Subject: Re: [cgal-discuss] triangulation face base with info
  • Date: Fri, 04 Sep 2009 12:23:41 +0200
  • Organization: INRIA
Ben Supnik wrote:
Hi Sylvain,
Does this mean that the info class attached to the face-base-with-info can have its ctors skipped?
Not for faces which are constructed, but for some triangulation modification
routines, faces are re-used. Imagine a simple flip : it's faster to just
update the pointers to the neighbors, rather than destructing the 2 faces,
and constructing 2 new ones. I don't think the manual promises anything
better.
If so, what happens if this class contains STL types that need initialization?
In the case the face object is re-used, the user info is unchanged.
As I said, an improved design would be to provide some visitor-like design
so that user-data can be properly updated upon updates or visits of the
triangulation. It's somewhere on the todo-list.
cheers
ben
Sylvain Pion wrote:
Sylvain Pion wrote:
cyril Bordreuil wrote:
hi everybody
I use a constrained triangulation 2 with face_base_info. In my constructor of info, i initialize a variable at -1.
Then, i insert a point in the triangulation. I thought that new face around the new vertex would be created but my variable
in info was not at -1. Any Hints?
Must i enforce every new face at -1?
I am afraid that there is currently no easy solution, you have to go over
all the "new" faces and re-initialize your data. This is not too hard
since in this case you only have to walk around the new vertex.
Following up to myself : there is actually a way to cheat, probably with
a small performance impact : define your face_base class in the hard way
(not using the with_info class), and overload its set_neighbor() function
so that it re-initialize your data.
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
