- To:
- Subject: Re: Res: [cgal-discuss] triangulation face base with info
- Date: Fri, 4 Sep 2009 14:06:39 +0200
Marcos, you should start a new discussion thread (do not answer to an
existing
message). Otherwise your message will not be read with enough attention by
most of the readers of this mailing list.
Le vendredi 04 septembre 2009 13:24:21, Marcos R. P. a écrit :
> Hi, Friends!
> I am face to problems with 120 erros messages in the Voronoi_diagram_2
> example from CGAL 3.4. I ran an other example, more simple, and have none
> erros.
> See the list bellow and try help me, please.
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(51) : error C2146: syntax
> error : missing ';' before identifier 'mpZ'
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(51) : error C4430: missing
> type specifier - int assumed. Note: C++ does not support default-int
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(54) : error C2065: 'mpZ' :
> undeclared identifier 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(54) :
> error C3861: 'mpz_clear': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(82) : error C4430: missing
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(82) : error C2146: syntax
> error : missing ',' before identifier 'z'
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(85) : error C2535:
> 'CGAL::Gmpz::Gmpz(const int)' : member function already defined or declared
> 1> c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(82) : see
> declaration of 'CGAL::Gmpz::Gmpz'
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(126) : error C4430: missing
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(126) : error C2143: syntax
> error : missing ';' before '&'
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(126) : warning C4183:
> 'mpz': missing return type; assumed to be a member function returning 'int'
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(127) : error C2143: syntax
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(127) : error C4430: missing
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(127) : warning C4183:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(79) : error C2758:
> 'CGAL::Gmpz::mpz_t' : must be initialized in constructor base/member
> initializer list 1>
> c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(126) : see declaration of
> 'CGAL::Gmpz::mpz_t' 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(79) :
> error C3861: 'mpz_init': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(82) : error C2758:
> initializer list 1>
> 'CGAL::Gmpz::mpz_t' 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(82) :
> error C2065: 'z' : undeclared identifier
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(82) : error C3861:
> 'mpz_init_set': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(85) : error C2758:
> initializer list 1>
> 'CGAL::Gmpz::mpz_t' 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(85) :
> error C3861: 'mpz_init_set_si': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(88) : error C2758:
> initializer list 1>
> 'CGAL::Gmpz::mpz_t' 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(88) :
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(91) : error C2758:
> initializer list 1>
> 'CGAL::Gmpz::mpz_t' 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(91) :
> error C3861: 'mpz_init_set_ui': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(94) : error C2758:
> initializer list 1>
> 'CGAL::Gmpz::mpz_t' 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(98) :
> error C3861: 'mpz_init_set_d': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(101) : error C2758:
> initializer list 1>
> 'CGAL::Gmpz::mpz_t' 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(101) :
> error C3861: 'mpz_init_set_str': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(126) : error C2039: 'mpZ' :
> is not a member of 'CGAL::Gmpz_rep' 1>
> c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(45) : see declaration of
> 'CGAL::Gmpz_rep' 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(127) :
> error C2039: 'mpZ' : is not a member of 'CGAL::Gmpz_rep' 1>
> 'CGAL::Gmpz_rep' 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(138) :
> error C2065: 'mp_bits_per_limb' : undeclared identifier
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(138) : error C3861:
> 'mpz_size': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(146) : error C3861:
> 'mpz_cmp': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(151) : error C3861:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(158) : error C3861:
> 'mpz_cmp_si': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(163) : error C3861:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(168) : error C3861:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(182) : error C3861:
> 'mpz_neg': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(192) : error C3861:
> 'mpz_add': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(203) : error C3861:
> 'mpz_add_ui': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(205) : error C3861:
> 'mpz_sub_ui': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(215) : error C3861:
> 'mpz_sub': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(226) : error C3861:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(228) : error C3861:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(238) : error C3861:
> 'mpz_mul': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(248) : error C3861:
> 'mpz_mul_si': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(259) : error C3861:
> 'mpz_tdiv_q': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(271) : error C3861:
> 'mpz_tdiv_q_ui': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(283) : error C3861:
> 'mpz_tdiv_r': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(292) : error C3861:
> 'mpz_get_d': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(297) : error C3861:
> 'mpz_sgn': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(302) : error C3861:
> 'mpz_sizeinbase': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(308) : error C3861:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(309) : error C3861:
> 'mpz_get_str': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(366) : error C2582:
> 'operator =' function is unavailable in 'CGAL::Gmpz'
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(381) : error C2582:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(388) : error C2582:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(390) : error C2582:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(452) : error C2582:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpz_type.h(453) : error C2582:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(55) : error C2146: syntax
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(55) : error C4430: missing
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(58) : error C3861:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(99) : error C4430: missing
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(99) : error C2143: syntax
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(100) : error C4430:
> missing type specifier - int assumed. Note: C++ does not support
> default-int 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(102) : warning
> C4183: 'man': missing return type; assumed to be a member function
> returning 'int' 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(104) :
> error C2143: syntax error : missing ';' before '&'
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(104) : error C4430:
> default-int 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(105) : error
> C4430: missing type specifier - int assumed. Note: C++ does not support
> default-int 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(107) : warning
> returning 'int' 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(125) :
> error C4430: missing type specifier - int assumed. Note: C++ does not
> support default-int 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(125) :
> error C2146: syntax error : missing ',' before identifier 'z'
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(141) : error C2535:
> 'CGAL::Gmpzf::Gmpzf(const int)' : member function already defined or
> declared 1> c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(125) :
> see declaration of 'CGAL::Gmpzf::Gmpzf'
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(200) : error C4430:
> default-int 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(200) : error
> C2143: syntax error : missing ',' before '*'
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(101) : error C2039: 'mpZ'
> : is not a member of 'CGAL::Gmpzf_rep' 1>
> c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(49) : see declaration of
> 'CGAL::Gmpzf_rep' 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(106) :
> error C2039: 'mpZ' : is not a member of 'CGAL::Gmpzf_rep' 1>
> 'CGAL::Gmpzf_rep' 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(119) :
> error C2758: 'CGAL::Gmpzf::mpz_t' : must be initialized in constructor
> base/member initializer list 1>
> c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(99) : see declaration of
> 'CGAL::Gmpzf::mpz_t' 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(120)
> : error C3861: 'mpz_init': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(127) : error C2758:
> 'CGAL::Gmpzf::mpz_t' : must be initialized in constructor base/member
> initializer list 1>
> 'CGAL::Gmpzf::mpz_t' 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(128)
> : error C2065: 'z' : undeclared identifier
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(128) : error C3861:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(135) : error C2758:
> initializer list 1>
> 'CGAL::Gmpzf::mpz_t' 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(136)
> : error C3861: 'mpz_init_set': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(143) : error C2758:
> initializer list 1>
> 'CGAL::Gmpzf::mpz_t' 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(144)
> : error C3861: 'mpz_init_set_si': identifier not found
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(150) : error C2758:
> initializer list 1>
> 'CGAL::Gmpzf::mpz_t' 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(151)
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(155) : error C2758:
> initializer list 1>
> 'CGAL::Gmpzf::mpz_t' 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(159)
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(167) : error C3861:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(224) : error C3861:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(235) : error C4430:
> default-int 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(235) : error
> C2143: syntax error : missing ';' before '*'
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(235) : error C2065:
> 'a_aligned' : undeclared identifier
> 'b_aligned' : undeclared identifier
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(236) : error C2065:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(237) : error C2065:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(237) : error C3861:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(254) : error C4430:
> default-int 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(254) : error
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(254) : error C2065:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(255) : error C2065:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(256) : error C2065:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(256) : error C3861:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(272) : error C3861:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(283) : error C3861:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(299) : error C4430:
> default-int 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(299) : error
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(299) : error C2065:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(300) : error C2065:
> 1>c:\cgal\cgal-3.4\include\cgal\gmp\gmpzf_type.h(300) : fatal error C1003:
> error count exceeds 100; stopping compilation 1>Build log was saved at
> "file://c:\Users\mrp\Documents\Visual Studio
> 2008\Projects\CGAL_t\Vteste\Debug\BuildLog.htm" 1>Vteste - 120 error(s), 4
> warning(s)
> ___________________________________________________________________________
>_________ Veja quais são os assuntos do momento no Yahoo! +Buscados
> http://br.maisbuscados.yahoo.com--
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Laurent Rineau, PhD
Release Manager of the CGAL Project
http://www.cgal.org/
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] triangulation face base with info, cyril Bordreuil, 09/04/2009
- Re: [cgal-discuss] triangulation face base with info, Sylvain Pion, 09/04/2009
- Re: [cgal-discuss] triangulation face base with info, Ben Supnik, 09/04/2009
- Res: [cgal-discuss] triangulation face base with info, Marcos R. P., 09/04/2009
- Re: Res: [cgal-discuss] triangulation face base with info, Laurent Rineau (GeometryFactory), 09/04/2009
- Re: [cgal-discuss] triangulation face base with info, Rahul Kavalapara, 09/04/2009
- Re: Re: [cgal-discuss] triangulation face base with info, Lionel, 09/07/2009
- Re: [cgal-discuss] triangulation face base with info, Sylvain Pion, 09/07/2009
