cgal-discuss - [cgal-discuss] 3D Boolean operations.
  • To:
  • Subject: [cgal-discuss] 3D Boolean operations.
  • Date: Mon, 7 Sep 2009 10:08:59 +0200 (CEST)
Hello all,
I am about to program an application using CGAL, which will be a
machining simulation (lathe)
Actually, I have already done such application using java and Jogl.
-> The reason why I plan to use CGAL is that it's possible to make 3D boolean
op.
As I want to show the result in real-time, I want to know how long does last
these op :
-> I do know that it's depending on a lot of parameters ! but, for instance :
I want to make a difference between :
2 cubes, on a standard machine (let's say a Intel core 2 duo E4300, 1.8G), how
long (about) does it last ?
The same questions but the différence between 2 spheres ?
Thank you in advance !
Gilles
  • [cgal-discuss] 3D Boolean operations., gilles.kneuss, 09/07/2009
