- To: <>
- Subject: [cgal-discuss] 2D mesh generation doesn't mesh my constrained triangulation
- Date: Mon, 21 Sep 2009 21:02:55 +0300
I enter a constraint triangulation by vertices, and then
operate the mesh generator, but I see no change. A little debugging indicated
that there were no bad faces. I tried it on several outputs which apparently
had bad faces, so it must be something in my definition. My definitions are: typedef
CGAL::Exact_predicates_inexact_constructions_kernel Kernel; typedef
CGAL::Triangulation_vertex_base_2<Kernel> FaceVertexBase; typedef
CGAL::Triangulation_vertex_base_with_info_2<MeshVertex*, Kernel,
FaceVertexBase> IFaceVertexBase; //MeshVertex is some object defined
earlier typedef
CGAL::Delaunay_mesh_face_base_2<Kernel> FaceFaceBase; template <class
Gt, class Fb
> class Enriched_face_base_2 : public
Fb { public: typedef Gt
Geom_traits; typedef typename Fb::Vertex_handle Vertex_handle; typedef typename Fb::Face_handle Face_handle; template < typename TDS2 > struct Rebind_TDS
{ typedef typename Fb::template
Rebind_TDS<TDS2>::Other Fb2; typedef
Enriched_face_base_2<Gt,Fb2> Other; }; protected: public: bool Inside; bool Inquired; Enriched_face_base_2(): Fb(), Inside(false), Inquired(false){}; Enriched_face_base_2(Vertex_handle v0, Vertex_handle v1, Vertex_handle v2) : Fb(v0,v1,v2), Inside(false),
Inquired(false) {}; Enriched_face_base_2(Vertex_handle v0, Vertex_handle v1, Vertex_handle v2, Face_handle n0, Face_handle n1, Face_handle n2) : Fb(v0,v1,v2,n0,n1,n2), Inside(false), Inquired(false)
{}; }; typedef Enriched_face_base_2<Kernel,
FaceFaceBase> IFaceBase; typedef
CGAL::Triangulation_data_structure_2<IFaceVertexBase, IFaceBase> Trids; typedef
CGAL::Constrained_Delaunay_triangulation_2<Kernel, Trids> MeshCDT; typedef
CGAL::Delaunay_mesh_size_criteria_2<MeshCDT> Criteria; typedef
CGAL::Delaunay_mesher_2<MeshCDT, Criteria> TriMesher; …entering
input as vertices in a MeshCDT object named “mCDT” CGAL::refine_Delaunay_mesh_2(mCDT,
Criteria(0.125, 0.5)); Thanks, Amir. |
- [cgal-discuss] 2D mesh generation doesn't mesh my constrained triangulation, Amir Vaxman, 09/21/2009
- Re: [cgal-discuss] 2D mesh generation doesn't mesh my constrained triangulation, Laurent Rineau (GeometryFactory), 09/23/2009
- RE: [cgal-discuss] 2D mesh generation doesn't mesh my constrained triangulation, Amir Vaxman, 09/23/2009
- Re: [cgal-discuss] 2D mesh generation doesn't mesh my constrained triangulation, Andreas Fabri, 09/23/2009
