cgal-discuss - Re: [cgal-discuss] 2D mesh generation doesn't mesh my constrained triangulation
  • To:
  • Subject: Re: [cgal-discuss] 2D mesh generation doesn't mesh my constrained triangulation
  • Date: Wed, 23 Sep 2009 13:50:13 +0200
Amir Vaxman wrote:
Thank you, I figured it out finally after debugging, worth mentioning in the
docs (or did I miss it?)
Hi Amir,
I think you missed it. Let me quote:
43.2 Meshes
43.2.1 Definitions
A mesh is a partition of a given region into simplices whose shapes and sizes
satisfy several criteria.
The domain is the region that the user wants to mesh. It has to be a bounded
region of the plane.
Source:
http://www.cgal.org/Manual/beta/doc_html/cgal_manual/Mesh_2/Chapter_main.html
andreas
-----Original Message-----
[mailto:] Sent: Wednesday, September 23, 2009 1:23 PM
To:
triangulation
Le lundi 21 septembre 2009 20:02:55, Amir Vaxman a écrit :
I enter a constraint triangulation by vertices, and then operate the mesh
generator, but I see no change. A little debugging indicated that there
were no bad faces. I tried it on several outputs which apparently had bad
faces, so it must be something in my definition. My definitions are:
In your constrained triangulation, do the constrained edges form a closed path? The 2D Mesh Generation algorithm needs a meshing domain. By default,
any face that cannot be reached from the infinite faces, without traversing a constrained edge, is inside the domain.
See the figures here:
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Mesh_2/Chapter_main.htm
l#Domain
If the polygons on those figures were not closed, then the meshing domain (painted in green) would be empty. If your constrained edges do not form a closed domain, then you need to insert a bounding box (four constrained
edges) in the constrained triangulation.
