RE: [cgal-discuss] 2D mesh generation doesn't mesh my constrained triangulation
- To: <>
- Subject: RE: [cgal-discuss] 2D mesh generation doesn't mesh my constrained triangulation
- Date: Wed, 23 Sep 2009 13:35:54 +0300
Thank you, I figured it out finally after debugging, worth mentioning in the
docs (or did I miss it?)
-----Original Message-----
[mailto:]
Sent: Wednesday, September 23, 2009 1:23 PM
To:
Subject: Re: [cgal-discuss] 2D mesh generation doesn't mesh my constrained
triangulation
Le lundi 21 septembre 2009 20:02:55, Amir Vaxman a écrit :
> I enter a constraint triangulation by vertices, and then operate the mesh
> generator, but I see no change. A little debugging indicated that there
> were no bad faces. I tried it on several outputs which apparently had bad
> faces, so it must be something in my definition. My definitions are:
In your constrained triangulation, do the constrained edges form a closed
path? The 2D Mesh Generation algorithm needs a meshing domain. By default,
any
face that cannot be reached from the infinite faces, without traversing a
constrained edge, is inside the domain.
See the figures here:
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Mesh_2/Chapter_main.htm
l#Domain
If the polygons on those figures were not closed, then the meshing domain
(painted in green) would be empty. If your constrained edges do not form a
closed domain, then you need to insert a bounding box (four constrained
edges)
in the constrained triangulation.
Laurent Rineau, PhD
Release Manager of the CGAL Project
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] 2D mesh generation doesn't mesh my constrained triangulation, Amir Vaxman, 09/21/2009
- Re: [cgal-discuss] 2D mesh generation doesn't mesh my constrained triangulation, Laurent Rineau (GeometryFactory), 09/23/2009
- RE: [cgal-discuss] 2D mesh generation doesn't mesh my constrained triangulation, Amir Vaxman, 09/23/2009
- Re: [cgal-discuss] 2D mesh generation doesn't mesh my constrained triangulation, Andreas Fabri, 09/23/2009
