cgal-discuss - RE: [cgal-discuss] 2D mesh generation doesn't mesh my constrained triangulation
  • To: <>
  • Subject: RE: [cgal-discuss] 2D mesh generation doesn't mesh my constrained triangulation
  • Date: Wed, 23 Sep 2009 15:18:01 +0300
Yes, Of course, I know it was supposed to be bounded. However, I wasn't
aware at first that the bounding edges have to manually set as the
constraint ones. The constraint edges I didn't constrain were those of the
convex hull of the vertices, which would exist anyhow.
Amir.
-----Original Message-----
[mailto:]
Sent: Wednesday, September 23, 2009 2:50 PM
To:
Subject: Re: [cgal-discuss] 2D mesh generation doesn't mesh my constrained
triangulation
Amir Vaxman wrote:
> Thank you, I figured it out finally after debugging, worth mentioning in
the
> docs (or did I miss it?)
Hi Amir,
I think you missed it. Let me quote:
43.2 Meshes
43.2.1 Definitions
A mesh is a partition of a given region into simplices whose shapes and
sizes satisfy several criteria.
The domain is the region that the user wants to mesh. It has to be a bounded
region of the plane.
Source:
http://www.cgal.org/Manual/beta/doc_html/cgal_manual/Mesh_2/Chapter_main.htm
l
andreas
> From: Laurent Rineau (GeometryFactory)
> [mailto:]
> Sent: Wednesday, September 23, 2009 1:23 PM
> To:
> triangulation
> Le lundi 21 septembre 2009 20:02:55, Amir Vaxman a écrit :
>> I enter a constraint triangulation by vertices, and then operate the mesh
>> generator, but I see no change. A little debugging indicated that there
>> were no bad faces. I tried it on several outputs which apparently had
bad
>> faces, so it must be something in my definition. My definitions are:
> In your constrained triangulation, do the constrained edges form a closed
> path? The 2D Mesh Generation algorithm needs a meshing domain. By default,
> any
> face that cannot be reached from the infinite faces, without traversing a
> constrained edge, is inside the domain.
> See the figures here:
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Mesh_2/Chapter_main.htm
> l#Domain
> If the polygons on those figures were not closed, then the meshing domain
> (painted in green) would be empty. If your constrained edges do not form a
> closed domain, then you need to insert a bounding box (four constrained
> edges)
> in the constrained triangulation.
