cgal-discuss - Re: [cgal-discuss] Polyhedron rendering in OpenGL
  • To:
  • Subject: Re: [cgal-discuss] Polyhedron rendering in OpenGL
  • Date: Wed, 30 Sep 2009 21:25:23 +0200
Laurent Rineau (GeometryFactory) a écrit :
Le mardi 29 septembre 2009 20:55:05,
a écrit :
Hello,
I'm a (very) beginner and I do need help (to start) !!!
I'm wondering how can get I from HDS (it's a Polyhedron) the proper vertex
to use afterwards
for rendering in OpenGL.
For example, I want to convert HDS into triplet of point (forming a
triangle)
-> Can anybody helps ?
That you so much for this little "coup de pouce"
You should have a look at the source code of the polyhedron demo, in demo/Polyhedron/, with CGAL>=3.4.
In CGAL-3.5, see the "draw" methods in Scene_polyhedron_item.cpp, and Scene_nef_polyhedron_item.cpp, which use code from demo/Polyhedron/include/CGAL/gl_render.h and demo/Polyhedron/Scene_nef_rendering.cpp.
The nef case shows the non-triangular case, which is far more complicated, as one has to triangulate each face of the polyhedron.
I hope that can help.
Hello Laurent,
I have now everything to make a beautiful application !
Thanks for help
Gilles
