cgal-discuss - Re: [cgal-discuss] installing boost (problem)
  • To:
  • Subject: Re: [cgal-discuss] installing boost (problem)
  • Date: Sat, 24 Oct 2009 20:45:09 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:reply-to:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:content-type; b=EzbZ3ttGbQT2yswW9nltIWIb3hEdb4EVIHQi/x3nGCNL7aR1iPrRBvz6izsTXVOW8x dQy4Qk/tatw6mQiphyTpxr5STTf2hzYfXJF811faY8BWWweYTA+X2FQ+1RdjIP9TFoqH 1UJX3AZ8icuGrgM1ongGTlTGtumBI6Ma8paAk=
Hi,
2009/10/24 <>
Hi,
I'm having some problems trying to instal boost 1.38. When i try to create a
new generator (in my case for Visual Studio 2008), i always get the same error:
CMake Error at CMakeLists.txt:61 (message):
 Magic variable CMAKE_IS_EXPERIMENTAL unset.
Have a look at the top of CMakeLists.txt:
message(STATUS " This is an alternate, cmake-based build system that is currently under development.")
message(STATUS " To try it out, invoke CMake with the argument")
message(STATUS " -DCMAKE_IS_EXPERIMENTAL=YES_I_KNOW")
message(STATUS " Or use the gui to set the variable CMAKE_IS_EXPERIMENTAL to some value.")
message(STATUS " This will only be necessary the first time.")
You can also have binary packages for windows and visual 2008 at www.boostpro.com/download. This will really be faster ...
Regards,
Olivier
can someone help me with this?
thanks
