- To:
- Subject: Re: Re: [cgal-discuss] installing boost (problem)
- Date: Sun, 25 Oct 2009 15:36:48 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type; b=fWS2Z1ZiSl6EnMw3f360AZRsjWlKazSXDcGj4deGyo3t2Vnj3f+Opm3rKdmwLym8up FUOt6KtXsc1OZW34M7jVZzdWR0gi/UQwqzR9kvrLATamslWS5SAiqcEbRMcvSKGthpwk w4kU1ZlMSXDRsg3JCyDSO0dmBfRXqmBMPlCrY=
Hi,
2009/10/25 <>
Maybe you can try to run in a command prompt:
cd where_is_located_boost_cmakelists.txt
cmake -DCMAKE_IS_EXPERIMENTAL=YES_I_KNOW .
(do not forget the '.' at the end of the line)
Or, you can look at the advanced values in cmake-gui, and change the value of CMAKE_IS_EXPERIMENTAL.
Hope it helps
Ragrds,
Olivier
Hi,
thanks for your help, but i didnt understand so well what i have to do to solve
the problem! My CMakeLists.txt just have this six line weird text:
# just install the modules
INSTALL_FILES(${CMAKE_DATA_DIR}/Templates .*\\.in)
INSTALL_FILES(${CMAKE_DATA_DIR}/Templates .*\\.txt)
INSTALL_FILES(${CMAKE_DATA_DIR}/Templates .*\\.cmake$)
INSTALL_FILES(${CMAKE_DATA_DIR}/Templates .*\\.dsptemplate$)
INSTALL_FILES(${CMAKE_DATA_DIR}/Templates .*\\.vsmacros$)
Hope it helps
Ragrds,
Olivier
About your other solution (downloading the windows installer of boost
1.38)...that was my first try. But it didnt work also, because of some transfer
errors during the setup.
Thanks
Regards
- [cgal-discuss] installing boost (problem), cristovao_jdc, 10/24/2009
- Re: [cgal-discuss] installing boost (problem), Olivier Tournaire, 10/24/2009
- Re: Re: [cgal-discuss] installing boost (problem), cristovao_jdc, 10/25/2009
- Re: Re: [cgal-discuss] installing boost (problem), Olivier Tournaire, 10/25/2009
- Re: Re: Re: [cgal-discuss] installing boost (problem), cristovao_jdc, 10/25/2009
- Re: [cgal-discuss] installing boost (problem), Laurent Rineau (GeometryFactory), 10/25/2009
