- To:
- Subject: Re: [cgal-discuss] installing boost (problem)
- Date: Sun, 25 Oct 2009 20:45:54 +0200
Le samedi 24 octobre 2009 16:49:26,
a écrit :
> Hi,
> I'm having some problems trying to instal boost 1.38. When i try to create
> a new generator (in my case for Visual Studio 2008), i always get the same
> error:
> CMake Error at CMakeLists.txt:61 (message):
> Magic variable CMAKE_IS_EXPERIMENTAL unset.
> can someone help me with this?
In Boost-1.38, the CMake support is experimental. If you want to use it, you
need to create a CMake variable named CMAKE_IS_EXPERIMENTAL, of type Boolean,
and set it to True. That is easier using the CMake GUI (cmake-gui.exe).
Maybe the CMake support is easier to use with more recent Boost versions.
Laurent Rineau, PhD
Release Manager of the CGAL Project
http://www.cgal.org/
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] installing boost (problem), cristovao_jdc, 10/24/2009
- Re: [cgal-discuss] installing boost (problem), Olivier Tournaire, 10/24/2009
- Re: Re: [cgal-discuss] installing boost (problem), cristovao_jdc, 10/25/2009
- Re: Re: [cgal-discuss] installing boost (problem), Olivier Tournaire, 10/25/2009
- Re: Re: Re: [cgal-discuss] installing boost (problem), cristovao_jdc, 10/25/2009
- Re: [cgal-discuss] installing boost (problem), Laurent Rineau (GeometryFactory), 10/25/2009
