- To:
- Subject: Re: [cgal-discuss] point location
- Date: Mon, 16 Nov 2009 23:22:22 +0200
Quoting "Catalin Suvei"
Hi,
I am a new user and consider using CGAL to help me with the point location
problem. I am going to use it in a finite element program; I presume that I
could build up the arrangement by adding the lines that make up each element
yes
(a question is if there is a method to add faces directly);
no
then I employ a
point location strategy and use it for a given point. My problem is that I
cannot map the object returned by this query (which can be a vertex, edge or
a face) to my finite element (consisting of nodes and elements). Any
suggestions? Ideally, I should be able to create a CGAL object representing
my finite element, store a pointer in this object to my finite element, then
add it to the arrangement and the point location query would return me the
CGAL object from where I could retrieve my finite element (or line/point
forming the finite element) and do something useful with it. Thanks a lot.
You probably need to extend the features of the dcel to store information regarding the originating elements. Look for a chapter in the doc. titled "Extending the Dcel". There are also examples that you can start playing with.
Catalin
- [cgal-discuss] point location, Catalin Suvei, 11/16/2009
- Re: [cgal-discuss] point location, efif, 11/16/2009
- RE: [cgal-discuss] point location, Catalin Suvei, 11/17/2009
- RE: [cgal-discuss] point location, efif, 11/17/2009
- Re: [cgal-discuss] point location, Andreas Fabri, 11/17/2009
- RE: [cgal-discuss] point location, Catalin Suvei, 11/18/2009
- Re: [cgal-discuss] point location, Andreas Fabri, 11/24/2009
- RE: [cgal-discuss] point location, Catalin Suvei, 11/24/2009
- RE: [cgal-discuss] point location, Catalin Suvei, 11/25/2009
