cgal-discuss - RE: [cgal-discuss] point location
  • To: <>
  • Subject: RE: [cgal-discuss] point location
  • Date: Tue, 17 Nov 2009 18:16:17 -0000
Hi,
Thanks very much, I'll look into that. I'll probably have to issue about 34
million queries on an arrangement formed by 3250 of 4 nodded faces, any idea,
roughly, how long it would take?
Catalin
-----Original Message-----
[mailto:]
Sent: 16 November 2009 21:22
To:
Subject: Re: [cgal-discuss] point location
Quoting "Catalin Suvei"
> Hi,
> I am a new user and consider using CGAL to help me with the point location
> problem. I am going to use it in a finite element program; I presume that I
> could build up the arrangement by adding the lines that make up each element
yes
> (a question is if there is a method to add faces directly);
no
then I employ a
> point location strategy and use it for a given point. My problem is that I
> cannot map the object returned by this query (which can be a vertex, edge or
> a face) to my finite element (consisting of nodes and elements). Any
> suggestions? Ideally, I should be able to create a CGAL object representing
> my finite element, store a pointer in this object to my finite element, then
> add it to the arrangement and the point location query would return me the
> CGAL object from where I could retrieve my finite element (or line/point
> forming the finite element) and do something useful with it. Thanks a lot.
You probably need to extend the features of the dcel to store
information regarding the originating elements. Look for a chapter in
the doc. titled "Extending the Dcel". There are also examples that you
can start playing with.
> Catalin
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
