cgal-discuss - RE: [cgal-discuss] point location
  • To: <>
  • Subject: RE: [cgal-discuss] point location
  • Date: Tue, 24 Nov 2009 16:59:51 -0000
Hi,
No, the elements are not necessarily rectangular nor they formed a perfect
grid. I tried CGAL in this example and it took hours to solve it.
Catalin
-----Original Message-----
[mailto:]
Sent: 24 November 2009 08:38
To:
Subject: Re: [cgal-discuss] point location
Hello,
sory for that it took so long before I come back to you.
I guess what you say with the bridge is just an example,
that is the elements are not necessarily all rectangular
and form a perfect grid.
If they formed a perfect grid, it would boil down to
sorting qeuery and grid points, and all data structures
we mentioned are just an overkill.
best regards,
andreas
Catalin Suvei wrote:
> Hi,
> Yes, the elements don't overlap, they just share edges and they have
> similar size.
> Basically the mesh is for bridge decks and we are modelling vehicles moving
> on these; so the query point would represent the wheel. Imagine a 150m x
> 24m bridge, meshed with 1m x 1m quad finite elements; the way we model the
> movement a vehicle is that we place the vehicle at every point in a grid of
> points, 0.25m apart in each direction; at every grid point we calculate the
> effect that vehicle has on the bridge, so that's why we need to find the
> finite element that contains wheel (point); once the vehicle is placed at a
> point, i could issue the query for all the wheels at once. So in my
> example, if there are 65,280 grid points and you have to check 87 vehicles,
> each having 6 wheels, you get 65,280 x 87 x 6 = 34,076,160 query points. I
> know If you are wondering why we need the finite element that contains the
> point is because we need to use the shape functions of that element to
> interpolate the value at that point.
> Sorry if I went into much detail, but I thought you might find it
> interesting.
> Catalin
> From: Andreas Fabri
> [mailto:]
> Sent: 17 November 2009 19:26
> To:
> Hello Catalin,
> Is it correct that your finite elements do not overlap, or at most on
> their boundary.
> If on the boundary, must they then share an entire edge, or can edges
> partially overlap?
> Are the finite elements of more or less homogeneous size, or can you
> have elements that traverse a huge fraction of the domain?
> Do you know all query points in advance?
> I ask this as there is the package http://www.cgal.org/Pkg/BoxIntersectionD
> which would allow you to apply a callback on all pairs of bounding
> boxes of the query points and the finite elements.
> You might also generate a Constrained triangulation of your input,
> (http://www.cgal.org/Pkg/Triangulation2 ) perform a spatial sort of your
> points ( http://www.cgal.org/Pkg/SpatialSorting ), and then run a point
> location
> for the sorted points, where you start your i+1st search at the face
> where the i-th point is located. With as many points as you have you
> will always be rather close.
> best regards,
> andreas
> wrote:
>> no, but I'll be happy to know the outcome of your experiment. BW, there
>> is a batch point location, which is based on the sweep-line framework.
>> It is more efficient for many query points, but you have to know them
>> ahead.
>> Quoting "Catalin Suvei"
>>> Hi,
>>> Thanks very much, I'll look into that. I'll probably have to issue
>>> about 34 million queries on an arrangement formed by 3250 of 4 nodded
>>> faces, any idea, roughly, how long it would take?
>>> Catalin
>>> From:
>>> [mailto:]
>>> Sent: 16 November 2009 21:22
>>> To:
>>>> Hi,
>>>> I am a new user and consider using CGAL to help me with the point
>>>> location
>>>> problem. I am going to use it in a finite element program; I presume
>>>> that I
>>>> could build up the arrangement by adding the lines that make up each
>>>> element
>>> yes
>>>> (a question is if there is a method to add faces directly);
>>> no
>>> then I employ a
>>>> point location strategy and use it for a given point. My problem is
>>>> that I
>>>> cannot map the object returned by this query (which can be a vertex,
>>>> edge or
>>>> a face) to my finite element (consisting of nodes and elements). Any
>>>> suggestions? Ideally, I should be able to create a CGAL object
>>>> representing
>>>> my finite element, store a pointer in this object to my finite
>>>> element, then
>>>> add it to the arrangement and the point location query would return
>>>> me the
>>>> CGAL object from where I could retrieve my finite element (or line/point
>>>> forming the finite element) and do something useful with it. Thanks a
>>>> lot.
>>> You probably need to extend the features of the dcel to store
>>> information regarding the originating elements. Look for a chapter in
>>> the doc. titled "Extending the Dcel". There are also examples that you
>>> can start playing with.
>>>> Catalin
>>>> You are currently subscribed to cgal-discuss.
>>>> To unsubscribe or access the archives, go to
>>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
