- To:
- Subject: RE: [cgal-discuss] point location
- Date: Tue, 17 Nov 2009 20:53:16 +0200
no, but I'll be happy to know the outcome of your experiment. BW, there is a batch point location, which is based on the sweep-line framework. It is more efficient for many query points, but you have to know them ahead.
Quoting "Catalin Suvei"
Hi,
Thanks very much, I'll look into that. I'll probably have to issue about 34 million queries on an arrangement formed by 3250 of 4 nodded faces, any idea, roughly, how long it would take?
Catalin
-----Original Message-----
[mailto:]
Sent: 16 November 2009 21:22
To:
Subject: Re: [cgal-discuss] point location
Hi,
I am a new user and consider using CGAL to help me with the point location
problem. I am going to use it in a finite element program; I presume that I
could build up the arrangement by adding the lines that make up each element
yes
(a question is if there is a method to add faces directly);
no
then I employ a
point location strategy and use it for a given point. My problem is that I
cannot map the object returned by this query (which can be a vertex, edge or
a face) to my finite element (consisting of nodes and elements). Any
suggestions? Ideally, I should be able to create a CGAL object representing
my finite element, store a pointer in this object to my finite element, then
add it to the arrangement and the point location query would return me the
CGAL object from where I could retrieve my finite element (or line/point
forming the finite element) and do something useful with it. Thanks a lot.
You probably need to extend the features of the dcel to store
information regarding the originating elements. Look for a chapter in
the doc. titled "Extending the Dcel". There are also examples that you
can start playing with.
Catalin
- [cgal-discuss] point location, Catalin Suvei, 11/16/2009
- Re: [cgal-discuss] point location, efif, 11/16/2009
- RE: [cgal-discuss] point location, Catalin Suvei, 11/17/2009
- RE: [cgal-discuss] point location, efif, 11/17/2009
- Re: [cgal-discuss] point location, Andreas Fabri, 11/17/2009
- RE: [cgal-discuss] point location, Catalin Suvei, 11/18/2009
- Re: [cgal-discuss] point location, Andreas Fabri, 11/24/2009
- RE: [cgal-discuss] point location, Catalin Suvei, 11/24/2009
- RE: [cgal-discuss] point location, Catalin Suvei, 11/25/2009
