- To:
- Subject: Re: [cgal-discuss] 3D Mesh Generation - Multi-domain
- Date: Tue, 17 Nov 2009 22:46:31 +0100
Le mardi 17 novembre 2009 21:38:17, Ramin H a écrit :
> Hello everybody,
> In the examples given in chapter 47, always one domain is passed to
> the mesh generator interface function:
> // 1. Create domain
> Mesh_domain domain(XXXX);
> // 2. Set criteria ...
> Mesh_criteria criteria(facet_criteria, cell_criteria);
> // 3. Generate mesh
> C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria);
> In the CGAL manual
> (http://www.cgal.org/Manual/3.5/doc_html/cgal_manual/Mesh_3/Chapter_main.ht
> ml), Figure 47.1 shows a multi-domain 3D mesh.
> The sub-domains are sharing boundaries in this mesh.
> Is there an example that shows how we should build these subdomains
> and pass them to mesh generation interface function to create the 3D
> mesh?
The corresponding example is in section *47.3.3 Mesh Generation From a
Segmented 3D Image*. See:
http://www.cgal.org/Manual/3.5/doc_html/cgal_manual/Mesh_3/Chapter_main.html#Subsection_47.3.3
Laurent Rineau, PhD
Release Manager of the CGAL Project
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] 3D Mesh Generation - Multi-domain, Ramin H, 11/17/2009
- Re: [cgal-discuss] 3D Mesh Generation - Multi-domain, Laurent Rineau (GeometryFactory), 11/17/2009
- Re: [cgal-discuss] 3D Mesh Generation - Multi-domain, Ramin H, 11/17/2009
- Re: [cgal-discuss] 3D Mesh Generation - Multi-domain, Stephane Tayeb, 11/20/2009
- Re: [cgal-discuss] 3D Mesh Generation - Multi-domain, Ramin H, 11/26/2009
