- To:
- Subject: Re: [cgal-discuss] 3D Mesh Generation - Multi-domain
- Date: Thu, 26 Nov 2009 16:58:01 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=kWVHzIIrWpn344p1qhcIhlFRLSPkJOgah3rUaW5+pn1IL7nvMJPQaMCyz9SYRADZdR GeBSm3KGiCgMdBf6a7L+TwvwBrcdRkDCBKdTPPisS7TjMOftsr9urZhKeMk+QZkngZ1E KOXtoIpeN7rmS1CIUvaMQpLrtU39vTIDeMiMQ=
Hi,
I am going to implement my own multi-domain polyhedron oracle.
I read
http://www.cgal.org/Manual/3.5/doc_html/cgal_manual/Mesh_3_ref/Concept_MeshDomain_3.html
but the information is very abstract.
Is there a technical report or a paper that can help me understand how
this should work?
Thank you,
-Ramin
On Fri, Nov 20, 2009 at 4:02 AM, Stephane Tayeb
wrote:
> Ramin H wrote:
>> Thank you for your response. I think I didn't ask my question
>> properly. I saw *47.3.3 Mesh Generation From a Segmented 3D Image*.
>> I wanted to know how the multi-domain input can be defined when using
>> polyhedron domains.
>> -Ramin
> Hi,
> There is no such thing in the current implementation.
> You will have to define your own multi-domain polyhedron oracle (cf.
> MeshDomain_3 concept in the reference manual). A naive (and computationnaly
> costly) solution could be to combine several polyhedron domains, one for
> each subdomain.
> Best,
> Stephane Tayeb
> Software engineer - INRIA Sophia Antipolis
> Geometrica Project-Team
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] 3D Mesh Generation - Multi-domain, Ramin H, 11/17/2009
- Re: [cgal-discuss] 3D Mesh Generation - Multi-domain, Laurent Rineau (GeometryFactory), 11/17/2009
- Re: [cgal-discuss] 3D Mesh Generation - Multi-domain, Ramin H, 11/17/2009
- Re: [cgal-discuss] 3D Mesh Generation - Multi-domain, Stephane Tayeb, 11/20/2009
- Re: [cgal-discuss] 3D Mesh Generation - Multi-domain, Ramin H, 11/26/2009
