- To:
- Subject: Re: [cgal-discuss] 3D Mesh Generation - Multi-domain
- Date: Tue, 17 Nov 2009 17:17:40 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=EdOZBtPYemsUOyd7uAga+xNNX/q63mdDp5efo0WSBAYNgeAJ5jJyvMbS0LTH0CbtRZ r5L5AEJqSjggavMrx5CHfiKPgKM0sxxKFMuoP8TrCcTEDA3T6/rhwT9tYG8VXiD4Puiv R2LvW+MKkmLRYWWN65cN3u/bftHy0DPDN9Jy8=
Thank you for your response. I think I didn't ask my question
properly. I saw *47.3.3 Mesh Generation From a Segmented 3D Image*.
I wanted to know how the multi-domain input can be defined when using
polyhedron domains.
-Ramin
On Tue, Nov 17, 2009 at 4:46 PM, Laurent Rineau (GeometryFactory)
wrote:
> Le mardi 17 novembre 2009 21:38:17, Ramin H a écrit :
>> Hello everybody,
>> In the examples given in chapter 47, always one domain is passed to
>> the mesh generator interface function:
>> // 1. Create domain
>> Mesh_domain domain(XXXX);
>> // 2. Set criteria ...
>> Mesh_criteria criteria(facet_criteria, cell_criteria);
>> // 3. Generate mesh
>> C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria);
>> In the CGAL manual
>> (http://www.cgal.org/Manual/3.5/doc_html/cgal_manual/Mesh_3/Chapter_main.ht
>> ml), Figure 47.1 shows a multi-domain 3D mesh.
>> The sub-domains are sharing boundaries in this mesh.
>> Is there an example that shows how we should build these subdomains
>> and pass them to mesh generation interface function to create the 3D
>> mesh?
> The corresponding example is in section *47.3.3 Mesh Generation From a
> Segmented 3D Image*. See:
> http://www.cgal.org/Manual/3.5/doc_html/cgal_manual/Mesh_3/Chapter_main.html#Subsection_47.3.3
> Laurent Rineau, PhD
> Release Manager of the CGAL Project
> R&D Engineer at GeometryFactory
> http://www.geometryfactory.com/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] 3D Mesh Generation - Multi-domain, Ramin H, 11/17/2009
- Re: [cgal-discuss] 3D Mesh Generation - Multi-domain, Laurent Rineau (GeometryFactory), 11/17/2009
- Re: [cgal-discuss] 3D Mesh Generation - Multi-domain, Ramin H, 11/17/2009
- Re: [cgal-discuss] 3D Mesh Generation - Multi-domain, Stephane Tayeb, 11/20/2009
- Re: [cgal-discuss] 3D Mesh Generation - Multi-domain, Ramin H, 11/26/2009
