- To:
- Subject: [cgal-discuss] [PATCH] Compile errors using Intels compiler icc
- Date: Fri, 27 Nov 2009 18:28:38 +0100
Hi,
I fail to use CGAL 3.5's header files with icc, the Intel compiler. I use
version 11.1 20091012 with the following options:
-fno-alias -strict-ansi -openmp -O3 -pg
The attached patch fixes it.
Please note that the GNU compiler has no problem with the code so I wonder
whether icc is right. I remembered
http://gcc.gnu.org/onlinedocs/gcc/Name-lookup.html#Name-lookup
"The C++ standard prescribes that all names that are not dependent on
template parameters are bound to their present definitions when parsing a
template function or class."
and tried adding "this->" for each problem which worked. There are probably
also other solutions such as a "using" directive.
Without the patch I get the following error:
/home/jens/Rhost/CGAL/CGAL-3.5/include/CGAL/HalfedgeDS_decorator.h|264|
error: identifier "find_prev" is undefined
|| Halfedge_handle hprev = find_prev( h);
|| detected during:
|| instantiation of "p_HDS::Halfedge_handle
CGAL::HalfedgeDS_decorator<p_HDS>::join_face(p_HDS::Halfedge_handle) [with
p_HDS=CGAL::HalfedgeDS_default<R,
CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>,
std::allocator<int>>]" at line 1169 of
"/home/jens/Rhost/CGAL/CGAL-3.5/include/CGAL/Polyhedron_3.h"
|| instantiation of "T_HDS<PolyhedronTraits_3,
CGAL::I_Polyhedron_derived_items_3<PolyhedronItems_3>,
Alloc>::Halfedge_handle CGAL::Polyhedron_3<PolyhedronTraits_3,
PolyhedronItems_3, T_HDS, Alloc>::join_facet(T_HDS<PolyhedronTraits_3,
Alloc>::Halfedge_handle) [with PolyhedronTraits_3=R,
PolyhedronItems_3=CGAL::Polyhedron_items_3, T_HDS=CGAL::HalfedgeDS_default,
Alloc=std::allocator<int>]" at line 246 of <one of my own files>
Jens
diff -ru CGAL-3.5/include/CGAL/HalfedgeDS_decorator.h CGAL-3.5.fixed/include/CGAL/HalfedgeDS_decorator.h --- CGAL-3.5/include/CGAL/HalfedgeDS_decorator.h 2009-07-24 14:42:18.000000000 +0200 +++ CGAL-3.5.fixed/include/CGAL/HalfedgeDS_decorator.h 2009-11-27 16:41:46.000000000 +0100 @@ -261,13 +261,13 @@ // size of the face removed and the time to compute `h->prev()'. // Precondition: `Supports_removal' == `Tag_true'. Assert_compile_time_tag( Tag_true(), Supports_removal()); - Halfedge_handle hprev = find_prev( h); - Halfedge_handle gprev = find_prev( h->opposite()); - remove_tip( hprev); - remove_tip( gprev); + Halfedge_handle hprev = this->find_prev( h); + Halfedge_handle gprev = this->find_prev( h->opposite()); + this->remove_tip( hprev); + this->remove_tip( gprev); hds->edges_erase( h); - if ( get_face( gprev) != Face_handle()) - faces_erase( get_face( gprev)); + if ( this->get_face( gprev) != Face_handle()) + this->faces_erase( this->get_face( gprev)); h = hprev; // 'half' of the halfedges have their correct faces. // Here we do the remaining halfedges. @@ -275,12 +275,12 @@ while ( h != gprev) { CGAL_assertion( ++termination_count != 0); h = h->next(); - set_face( h, get_face( hprev)); + this->set_face( h, this->get_face( hprev)); } - if ( get_face( hprev) != Face_handle()) - set_face_halfedge( hprev); - set_vertex_halfedge( hprev); - set_vertex_halfedge( gprev); + if ( this->get_face( hprev) != Face_handle()) + this->set_face_halfedge( hprev); + this->set_vertex_halfedge( hprev); + this->set_vertex_halfedge( gprev); return hprev; } @@ -311,12 +311,12 @@ // removed and the time to compute `h->prev()'. Precondition: // `Supports_removal' == `Tag_true'. Assert_compile_time_tag( Tag_true(), Supports_removal()); - Halfedge_handle hprev = find_prev( h->opposite()); - Halfedge_handle gprev = find_prev( h); - remove_halfedge( hprev); - remove_halfedge( gprev); + Halfedge_handle hprev = this->find_prev( h->opposite()); + Halfedge_handle gprev = this->find_prev( h); + this->remove_halfedge( hprev); + this->remove_halfedge( gprev); hds->edges_erase( h); - vertices_erase( get_vertex( gprev)); + vertices_erase( this->get_vertex( gprev)); // 'half' of the halfedges have their correct vertex. // Here we do the remaining halfedges. h = hprev; @@ -324,13 +324,13 @@ while ( h != gprev) { CGAL_assertion( ++termination_count != 0); h = h->next()->opposite(); - set_vertex( h, get_vertex( hprev)); + this->set_vertex( h, this->get_vertex( hprev)); } - set_vertex_halfedge( hprev); + this->set_vertex_halfedge( hprev); if ( ! hprev->is_border()) - set_face_halfedge( hprev); + this->set_face_halfedge( hprev); if ( ! gprev->is_border()) - set_face_halfedge( gprev); + this->set_face_halfedge( gprev); return hprev; } @@ -555,16 +555,16 @@ CGAL_precondition( h != Halfedge_handle()); CGAL_precondition( h->is_border()); Face_handle f = faces_push_back( Face()); - set_face_in_face_loop( h, f); - set_face_halfedge( h); + this->set_face_in_face_loop( h, f); + this->set_face_halfedge( h); } void fill_hole( Halfedge_handle h, const Face& f, Tag_true) { CGAL_precondition( h != Halfedge_handle()); CGAL_precondition( h->is_border()); Face_handle fh = faces_push_back( f); - set_face_in_face_loop( h, fh); - set_face_halfedge( h); + this->set_face_in_face_loop( h, fh); + this->set_face_halfedge( h); } public: @@ -607,8 +607,8 @@ CGAL_precondition( h->is_border()); CGAL_precondition( g->is_border()); Halfedge_handle hh = hds->edges_push_back( Halfedge(), Halfedge()); - insert_tip( hh, h); - insert_tip( hh->opposite(), g); + this->insert_tip( hh, h); + this->insert_tip( hh->opposite(), g); fill_hole( g, f); return hh; }
- [cgal-discuss] [PATCH] Compile errors using Intels compiler icc, Jens Seidel, 11/27/2009
- Re: [cgal-discuss] [PATCH] Compile errors using Intels compiler icc, Laurent Rineau (GeometryFactory), 11/27/2009
- Re: [cgal-discuss] [PATCH] Compile errors using Intels compiler icc, Jens Seidel, 11/27/2009
