- To:
- Subject: Re: [cgal-discuss] [PATCH] Compile errors using Intels compiler icc
- Date: Fri, 27 Nov 2009 20:41:42 +0100
On Friday 27 November 2009 18:28:38 Jens Seidel wrote:
> Hi,
> I fail to use CGAL 3.5's header files with icc, the Intel compiler. I use
> version 11.1 20091012 with the following options:
> -fno-alias -strict-ansi -openmp -O3 -pg
Which operating system?
Do you have the same errors without -strict-ansi?
What is the version of your g++ compiler?
Which cpp files you compiling when you found out that compilation error?
Until today, the CGAL testsuite process was still using version 11.0 of the
compiler. The testsuite results using Intel C++ Compiler version 11.0 does
not
show the same compilation bug as yours.
I have added the Intel C++ compiler version 11.1 in the set of tested
compilers. I will have new test results using 11.1 in about one hour. I would
like to reproduce your error, to be sure that our testsuite does not let pass
incorrect code.
Laurent Rineau, PhD
- [cgal-discuss] [PATCH] Compile errors using Intels compiler icc, Jens Seidel, 11/27/2009
- Re: [cgal-discuss] [PATCH] Compile errors using Intels compiler icc, Laurent Rineau (GeometryFactory), 11/27/2009
- Re: [cgal-discuss] [PATCH] Compile errors using Intels compiler icc, Jens Seidel, 11/27/2009
