cgal-discuss - Re: [cgal-discuss] [PATCH] Compile errors using Intels compiler icc
  • To:
  • Subject: Re: [cgal-discuss] [PATCH] Compile errors using Intels compiler icc
  • Date: Fri, 27 Nov 2009 21:28:01 +0100
On Fri, Nov 27, 2009 at 08:41:42PM +0100, Laurent Rineau (GeometryFactory)
wrote:
> On Friday 27 November 2009 18:28:38 Jens Seidel wrote:
> > I fail to use CGAL 3.5's header files with icc, the Intel compiler. I use
> > version 11.1 20091012 with the following options:
> > -fno-alias -strict-ansi -openmp -O3 -pg
> Which operating system?
Linux, what else?
> Do you have the same errors without -strict-ansi?
No, it's indeed this option which causes trouble. I suggest you use this in
your tests as well as you want to be standard conform, right? Same for gcc
options such as -pedantic -ansi ...
> What is the version of your g++ compiler?
Various, I even test sometimes snapshots of g++. icc always caused trouble
in the past (a lot of internal compiler errors, still true if I do not
outcomment my openmp directives), this time it worked for the first time.
> Which cpp files you compiling when you found out that compilation error?
Please first test with the -strict-ansi option. If you do not get errors
I will try to create a minimal test case for you.
Thanks,
Jens
