- To:
- Subject: Re: [cgal-discuss] [PATCH] Compile errors using Intels compiler icc
- Date: Fri, 27 Nov 2009 21:29:28 +0100
On Friday 27 November 2009 20:41:42 Laurent Rineau (GeometryFactory) wrote:
> On Friday 27 November 2009 18:28:38 Jens Seidel wrote:
> > Hi,
> > I fail to use CGAL 3.5's header files with icc, the Intel compiler. I use
> > version 11.1 20091012 with the following options:
> > -fno-alias -strict-ansi -openmp -O3 -pg
> Which operating system?
> Do you have the same errors without -strict-ansi?
> What is the version of your g++ compiler?
> Which cpp files you compiling when you found out that compilation error?
> Until today, the CGAL testsuite process was still using version 11.0 of the
> compiler. The testsuite results using Intel C++ Compiler version 11.0 does
> not show the same compilation bug as yours.
> I have added the Intel C++ compiler version 11.1 in the set of tested
> compilers. I will have new test results using 11.1 in about one hour. I
> would like to reproduce your error, to be sure that our testsuite does not
> let pass incorrect code.
The test results with Intel C++ 11.1 has not shown any particular compilation
error. Can you send us a cpp file that does *not* compile with the patch? It
may be a piece of code that is not tested with the CGAL testsuite (and that
is
a problem!).
Laurent Rineau, PhD
- [cgal-discuss] [PATCH] Compile errors using Intels compiler icc, Jens Seidel, 11/27/2009
- Re: [cgal-discuss] [PATCH] Compile errors using Intels compiler icc, Laurent Rineau (GeometryFactory), 11/27/2009
- Re: [cgal-discuss] [PATCH] Compile errors using Intels compiler icc, Jens Seidel, 11/27/2009
