- To:
- Subject: Re: [cgal-discuss] A geometry question
- Date: Thu, 3 Dec 2009 11:32:07 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=CfTerDiq9HDuEkBvh8oqjrpu55q8FE+AMxe26u4Fj55Fiu6fJEqxeDhaLGY4Jsp4Ib 9oxKeDGkoVibScEgqfG07O7aNXFNTucX4k9Tih5nFxuR0e4YMoWg9GU5QV05h+nmuh+O KAc++eH5p3cs2L1fRtP+lSMiVhbGHggLF1/B0=
Actually "farthest" from will not work...
On Thu, Dec 3, 2009 at 11:30 AM, Stephen Sintay <> wrote:
Can this problem be formulated in another way?
Given two triangular patches, find the largest sphere that is tangent to both.
The solution to this should be a simple as finding a point/line in each patch that is farthest from the other patch. This should be a simple matter of testing the nodes.
I might try the following:
For each patch, p_i{
compute the normal n_i
For each patch p_j
if( i!=j){
compute the normal n_j
if (n_i dot n_j >1 ){
compute the largest sphere
compute if any portion of sphere is external to polygon
If(no external sphere portions){
if( R_i < R_ij )
save sphere R_ij as largest for p_i
} end internal
} end dot
} end i!=j
} end p_j
} end p_iOn Thu, Dec 3, 2009 at 1:09 AM, Bernd Gaertner <> wrote:
Atul Thakur wrote:[snip]
A polyhedron (non-convex with triangles as its bounding facets) is
given. For a given facet determine the maximum sized sphere that is
tangential to the facet and contained completely inside the
polyhedron.
This optimization problem is no good. A sphere can be penetrating a facet even if it does not has any of the points inside. And by summing up constraints, you will have them satisfied only "on average" but not individually.
3. Solve following optimization problem:
Maximize R
S.T.
nR^2 - Sum[(x_j - P_center) dot(x_j - P_center) ] >= 0 (as all points
x_j lying on the polyhedron surface lie outside or on the sphere)
0<alpha, beta, gamma<1
R>0
Best,
Bernd.
- [cgal-discuss] A geometry question, Atul Thakur, 12/02/2009
- Re: [cgal-discuss] A geometry question, Bernd Gaertner, 12/03/2009
- Re: [cgal-discuss] A geometry question, Stephen Sintay, 12/03/2009
- Re: [cgal-discuss] A geometry question, Atul Thakur, 12/03/2009
