cgal-discuss - Re: [cgal-discuss] A geometry question
  • To:
  • Subject: Re: [cgal-discuss] A geometry question
  • Date: Thu, 3 Dec 2009 16:38:10 -0500
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type:content-transfer-encoding; b=JLkmA42PIJfhTCurGBnfXTx3q5AVCax7iBu6yliuIgn85sFw9GCNsG17vkkcARXAg3 M2DyrRXP3yr5qZSsJ3pVdQyl9ioYUc/q+CR1ywi22zlLHOb1pjdQLGkgs3A1HDD87Q2/ 4P5iM7T/PYXz/8ctlCM/l+awcPbgdjROKe9Fs=
Yes.
Actually, as Bernd pointed out my 1st constraint is not right.
It should be replaced by n different constraints as
R^2 - sq_dist(Triangle(x_j1, x_j2, x_j3), P_center)>= 0
where, n is number of facets,
x_j1, x_j2, x_j3 are vertices of j'th triangle.
which makes it 4 variable and n+7 constraints and needs to be solved n times
-Atul
On Thu, Dec 3, 2009 at 4:25 PM, Stephen Sintay
wrote:
> Now that I think about this a little more, I think what you are looking for
> is the medial axis or skeleton of the polygon.
> The location of the center of all the spheres that satisfy your condition
> will trace the medial axis or skeleton of the polygon.
> On Thu, Dec 3, 2009 at 11:32 AM, Stephen Sintay
> wrote:
>> Actually "farthest" from will not work...
>> On Thu, Dec 3, 2009 at 11:30 AM, Stephen Sintay
>> wrote:
>>> Can this problem be formulated in another way?
>>> Given two triangular patches, find the largest sphere that is tangent to
>>> both.
>>> The solution to this should be a simple as finding a point/line in each
>>> patch that is farthest from the other patch. This should be a simple
>>> matter
>>> of testing the nodes.
>>> I might try the following:
>>> For each patch, p_i{
>>>   compute the normal n_i
>>>   For each patch p_j
>>>   if( i!=j){
>>>     compute the normal n_j
>>>     if (n_i dot n_j >1 ){
>>>        compute the largest sphere
>>>        compute if any portion of sphere is external to polygon
>>>        If(no external sphere portions){
>>>            if( R_i < R_ij )
>>>              save sphere R_ij as largest for p_i
>>>        } end internal
>>>     } end dot
>>>    } end i!=j
>>>  } end p_j
>>> } end p_i
>>> On Thu, Dec 3, 2009 at 1:09 AM, Bernd Gaertner
>>> wrote:
>>>> Atul Thakur wrote:
>>>>> A polyhedron (non-convex with triangles as its bounding facets) is
>>>>> given. For a given facet determine the maximum sized sphere that is
>>>>> tangential to the facet and contained completely inside the
>>>>> polyhedron.
>>>> [snip]
>>>>> 3. Solve following optimization problem:
>>>>> Maximize R
>>>>> S.T.
>>>>> nR^2 - Sum[(x_j - P_center) dot(x_j - P_center) ] >= 0 (as all points
>>>>> x_j lying on the polyhedron surface lie outside or on the sphere)
>>>>> 0<alpha, beta, gamma<1
>>>>> R>0
>>>> This optimization problem is no good. A sphere can be penetrating a
>>>> facet even if it does not has any of the points inside. And by summing up
>>>> constraints, you will have them satisfied only "on average" but not
>>>> individually.
>>>> Best,
>>>> Bernd.
>>>> You are currently subscribed to cgal-discuss.
>>>> To unsubscribe or access the archives, go to
>>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
