- To:
- Subject: Re: [cgal-discuss] genearting a mesh from cloud points
- Date: Tue, 8 Dec 2009 00:11:48 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=afb1dhbEESAQ8Psx2v2nFoSDxheWAE6MCazOUO4sdBN8LmsuDq+PlyfTMKVt3Agqvk 5I95YIHMval8vyRB4y/25JHVpmr0uV7diTVIGAmzeuO1ti4FzueHYESE7+kx0mjkq/W0 OlBQHWEfgDDqHhJ8++N/li3C67Q6wvpn2QXX0=
2009/12/7 sara shafaei <>
register + merge a couple of scans you mean?
can u be more specific?
cheers
Hey guys, I was trying to generate a mesh from cloud points.
I know there is a chapter in CGAL for that. I was trying to put the pipeline which came in the manual together , but it caused error when I put the example in the one program. Is there anyone that has a demo for whole process. I appreciate your help.
cheers
Thank you,
Sara
\\v//
(o o)
--ooO-(_)-Ooo-----------------
-------- Nikos Yiotis
- [cgal-discuss] how to Check is point inside convex hull 3d?, mahdavi, 12/07/2009
- [cgal-discuss] genearting a mesh from cloud points, sara shafaei, 12/07/2009
- Re: [cgal-discuss] genearting a mesh from cloud points, ny, 12/08/2009
- Re: [cgal-discuss] genearting a mesh from cloud points, sara shafaei, 12/08/2009
- Re: [cgal-discuss] genearting a mesh from cloud points, Pierre Alliez, 12/09/2009
- Re: [cgal-discuss] how to Check is point inside convex hull 3d?, Bernd Gaertner, 12/08/2009
- Re: [cgal-discuss] how to Check is point inside convex hull 3d?, Andreas Fabri, 12/08/2009
