- To:
- Subject: Re: [cgal-discuss] genearting a mesh from cloud points
- Date: Tue, 8 Dec 2009 00:46:58 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=osyNnHc4lVRM4MbgOO8rsCfhGbCDrzPE6FtmNegGNW+lg/ochZrM2bAMGG7V1GPofp 9D8UAo3WZXXn9EJMcwXJt2nUq4qLO3qqH1Dsnookdo0yzDf3trPmlrJk5GGgJvpzOWR8 +q3uR9z6djpd6vZjTlmXKxHUmUdBbfYxa19Zs=
state-of-the-art
http://people.cs.ubc.ca/~hhzhiyan/consolidation.html
\\v//
(o o)
--ooO-(_)-Ooo-----------------
-------- Nikos Yiotis
2009/12/8 sara shafaei <>
Sure, I have a unorganized point set without normals . I want to do triangulation on them. First, I need to do some preprocessing such as : Simplification, outlier removal, smoothing, normal estimation. There are some examples for each of them here:
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Point_set_processing_3/Chapter_main.html
but when I try to put them together as a pipeline . it doesn't work.
Thank you,
Sara
To:
Date: Tuesday, December 8, 2009, 2:41 AM2009/12/7 sara shafaei <>
Hey guys, I was trying to generate a mesh from cloud points.
register + merge a couple of scans you mean?
I know there is a chapter in CGAL for that. I was trying to put the pipeline which came in the manual together , but it caused error when I put the example in the one program. Is there anyone that has a demo for whole process. I appreciate your help.
can u be more specific?
cheers
Thank you,
Sara
\\v//
(o o)
- [cgal-discuss] how to Check is point inside convex hull 3d?, mahdavi, 12/07/2009
- [cgal-discuss] genearting a mesh from cloud points, sara shafaei, 12/07/2009
- Re: [cgal-discuss] genearting a mesh from cloud points, ny, 12/08/2009
- Re: [cgal-discuss] genearting a mesh from cloud points, sara shafaei, 12/08/2009
- Re: [cgal-discuss] genearting a mesh from cloud points, Pierre Alliez, 12/09/2009
- Re: [cgal-discuss] how to Check is point inside convex hull 3d?, Bernd Gaertner, 12/08/2009
- Re: [cgal-discuss] how to Check is point inside convex hull 3d?, Andreas Fabri, 12/08/2009
