cgal-discuss - Re: [cgal-discuss] genearting a mesh from cloud points
  • To:
  • Subject: Re: [cgal-discuss] genearting a mesh from cloud points
  • Date: Wed, 09 Dec 2009 10:20:17 -0800
  • Organization: INRIA
hi Sara,
please be more precise: where does it fail - can you send a snapshot of your point set and results?
thank you,
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee
Project-team GEOMETRICA
http://www-sop.inria.fr/members/Pierre.Alliez/
Tel: +33 4 92 38 76 77
Fax: +33 4 97 15 53 95
sara shafaei a écrit :
Sure, I have a unorganized point set without normals . I want to do triangulation on them. First, I need to do some preprocessing such as : Simplification, outlier removal, smoothing, normal estimation. There are some examples for each of them here:
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Point_set_processing_3/Chapter_main.html
but when I try to put them together as a pipeline . it doesn't work.
Thank you,
Sara
To:
Date: Tuesday, December 8, 2009, 2:41 AM
2009/12/7 sara shafaei <>
Hey guys,
I was trying to generate a mesh from cloud points.
register + merge a couple of scans you mean?
I know there is a chapter in CGAL for that. I was trying to put the pipeline which came in the manual together , but it caused error when I put the example in the one program. Is there anyone that has a demo for whole process. I appreciate your help.
can u be more specific?
cheers
Thank you,
Sara
Chat Skype: nyiotis
Contact Me LinkedinTwitter
        \\v//
   (o o)
--ooO-(_)-Ooo-----------------
--------             Nikos Yiotis
