- To:
- Subject: [cgal-discuss] error in using CGAL::grid_simplify_point_set
- Date: Tue, 8 Dec 2009 12:22:23 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=TtxPhSPMGTOkAxLucYEBtS5SPAuqR1cw7Fi8ig257Gisk4nveQJljR2TRXUtS5hRPg SpaawA7A9FAizD90aGKdVaAaMwdmpR1rkPDP97861R0Fc5MURrX7ZNLFlvbfQTsIXNpb W1xDGN40k0fxVyjHc8mjNuYcLAcuFNob/hT+s=
Hi all,
I am trying to use following function:
points.erase(CGAL::grid_simplify_point_set(points.begin(), points.end(), cell_size),
points.end());
the type that I am using for points is :
// types
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
typedef Kernel::Point_3 Point;
typedef Kernel::Vector_3 Vector;
// Point with normal vector stored in a std::pair.
typedef std::pair<Point, Vector> PointVectorPair;
std::list<PointVectorPair> points;
but it caused error. I want to keep this type for points. Do you have any suggestion to fix it.
Thank you,
Tina
- [cgal-discuss] error in using CGAL::grid_simplify_point_set, tina rumi, 12/08/2009
- Re: [cgal-discuss] error in using CGAL::grid_simplify_point_set, Nader SALMAN, 12/08/2009
- Re: [cgal-discuss] error in using CGAL::grid_simplify_point_set, tina rumi, 12/08/2009
- Re: [cgal-discuss] error in using CGAL::grid_simplify_point_set, Laurent Saboret, 12/09/2009
- Re: [cgal-discuss] error in using CGAL::grid_simplify_point_set, Nader Salman, 12/09/2009
- Re: [cgal-discuss] error in using CGAL::grid_simplify_point_set, tina rumi, 12/09/2009
- Re: [cgal-discuss] error in using CGAL::grid_simplify_point_set, Nader SALMAN, 12/10/2009
- Re: [cgal-discuss] error in using CGAL::grid_simplify_point_set, tina rumi, 12/10/2009
- Re: [cgal-discuss] error in using CGAL::grid_simplify_point_set, Nader SALMAN, 12/11/2009
