cgal-discuss - Re: [cgal-discuss] error in using CGAL::grid_simplify_point_set
  • To:
  • Subject: Re: [cgal-discuss] error in using CGAL::grid_simplify_point_set
  • Date: Wed, 09 Dec 2009 09:41:06 +0100
  • Organization: INFOTERRA
Hi Tina,
Could you please post your complete code, so we can try to reproduce the compilation error below.
Best regards,
Laurent Saboret
tina rumi wrote:
Hi Nad,
Thanks a lot for your help. I am getting another error when I am running your code. here is the error that I got:
1>Compiling...
1>cloud_points.cpp
1>c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(61) : error C2039: 'x' : is not a member of 'std::pair<_Ty1,_Ty2>'
1>        with
1>        [
1>            _Ty1=Point,
1>            _Ty2=Vector
1>        ]
1>        c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(59) : while compiling class template member function 'bool CGAL::CGALi::Less_epsilon_points_3<Point_3>::operator ()(const Point_3 &,const Point_3 &) const'
1>        with
1>        [
1>            Point_3=Enriched_point
1>        ]
1>        c:\program files (x86)\microsoft visual studio 9.0\vc\include\set(48) : see reference to class template instantiation 'CGAL::CGALi::Less_epsilon_points_3<Point_3>' being compiled
1>        with
1>        [
1>        ]
1>        c:\program files (x86)\microsoft visual studio 9.0\vc\include\xtree(22) : see reference to class template instantiation 'std::_Tset_traits<_Kty,_Pr,_Alloc,_Mfl>' being compiled
1>        with
1>        [
1>            _Kty=Enriched_point,
1>            _Pr=CGAL::CGALi::Less_epsilon_points_3<Enriched_point>,
1>            _Alloc=std::allocator<PointVectorPair>,
1>            _Mfl=false
1>        ]
1>        c:\program files (x86)\microsoft visual studio 9.0\vc\include\xtree(63) : see reference to class template instantiation 'std::_Tree_nod<_Traits>' being compiled
1>        with
1>        [
1>            _Traits=std::_Tset_traits<Enriched_point,CGAL::CGALi::Less_epsilon_points_3<Enriched_point>,std::allocator<PointVectorPair>,false>
1>        ]
1>        c:\program files (x86)\microsoft visual studio 9.0\vc\include\xtree(89) : see reference to class template instantiation 'std::_Tree_ptr<_Traits>' being compiled
1>        with
1>        [
1>        ]
1>        c:\program files (x86)\microsoft visual studio 9.0\vc\include\xtree(107) : see reference to class template instantiation 'std::_Tree_val<_Traits>' being compiled
1>        with
1>        [
1>        ]
1>        c:\program files (x86)\microsoft visual studio 9.0\vc\include\set(57) : see reference to class template instantiation 'std::_Tree<_Traits>' being compiled
1>        with
1>        [
1>        ]
1>        c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(99) : see reference to class template instantiation 'std::set<_Kty,_Pr>' being compiled
1>        with
1>        [
1>        ]
1>        c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(154) : see reference to class template instantiation 'CGAL::Epsilon_point_set_3<Point_3>' being compiled
1>        with
1>        [
1>        ]
1>        c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(190) : see reference to function template instantiation 'ForwardIterator CGAL::grid_simplify_point_set<ForwardIterator,PointPMap,CGAL::Filtered_kernel<CK>>(ForwardIterator,ForwardIterator,PointPMap,double,const Kernel &)' being compiled
1>        with
1>        [
1>            ForwardIterator=std::_Vector_iterator<PointVectorPair,std::allocator<PointVectorPair>>,
1>            PointPMap=CGAL::First_of_pair_property_map<PointVectorPair>,
1>            CK=CGAL::Simple_cartesian<double>,
1>            Kernel=CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>>
1>        ]
1>        f:\fingerprint\codes\cloud_points\cloud_points\cloud_points.cpp(203) : see reference to function template instantiation 'ForwardIterator CGAL::grid_simplify_point_set<std::_Vector_iterator<_Ty,_Alloc>,CGAL::First_of_pair_property_map<Pair>>(ForwardIterator,ForwardIterator,PointPMap,double)' being compiled
1>        with
1>        [
1>            _Ty=PointVectorPair,
1>            Pair=PointVectorPair,
1>        ]
1>c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(62) : error C2039: 'y' : is not a member of 'std::pair<_Ty1,_Ty2>'
1>        with
1>        [
1>            _Ty1=Point,
1>            _Ty2=Vector
1>        ]
1>c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(63) : error C2039: 'z' : is not a member of 'std::pair<_Ty1,_Ty2>'
1>        with
1>        [
1>            _Ty1=Point,
1>            _Ty2=Vector
1>        ]
1>c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(63) : error C2661: 'std::pair<_Ty1,_Ty2>::pair' : no overloaded function takes 3 arguments
1>        with
1>        [
1>            _Ty1=Point,
1>            _Ty2=Vector
1>        ]
1>c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(64) : error C2039: 'x' : is not a member of 'std::pair<_Ty1,_Ty2>'
1>        with
1>        [
1>            _Ty1=Point,
1>            _Ty2=Vector
1>        ]
1>c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(65) : error C2039: 'y' : is not a member of 'std::pair<_Ty1,_Ty2>'
1>        with
1>        [
1>            _Ty1=Point,
1>            _Ty2=Vector
1>        ]
1>c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(66) : error C2039: 'z' : is not a member of 'std::pair<_Ty1,_Ty2>'
1>        with
1>        [
1>            _Ty1=Point,
1>            _Ty2=Vector
1>        ]
1>c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(66) : error C2661: 'std::pair<_Ty1,_Ty2>::pair' : no overloaded function takes 3 arguments
1>        with
1>        [
1>            _Ty1=Point,
1>            _Ty2=Vector
1>        ]
1>Build log was saved at "file://f:\fingerprint\codes\cloud_points\cloud_points\Debug\BuildLog.htm"
1>cloud_points - 8 error(s), 0 warning(s)
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
Thank you,
Tina
On Tue, Dec 8, 2009 at 12:57 PM, Nader SALMAN <> wrote:
A correction , here you go :
// kernel
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
// Simple geometric types
typedef Kernel::FT FT;
typedef Kernel::Point_3 Point;
typedef Kernel::Vector_3 Vector;
// Point with normal vector stored in a std::pair.
typedef std::pair<Point, Vector> PointVectorPair;
typedef std::vector<PointVectorPair> PointList;
PointList points // Type of input point set
// simplification by clustering using erase-remove idiom
double cell_size = 0.001;
PointList::iterator unwanted_points_begin = CGAL::grid_simplify_point_set(points.begin(), points.end(), CGAL::First_of_pair_property_map<PointVectorPair>(), cell_size);
// delete unwanted points
points.erase(
unwanted_points_begin , points.end());
// Optional: after erase(), use Scott Meyer's "swap trick" to trim excess capacity
PointList(points).swap(points);
Sorry for the earlier message,
Cheers,
Nad.
Nader SALMAN
Nader SALMAN a écrit :
Hi Tina,
thank you for your interest in CGAl and for using the PSP package.
here is how you should do it in general :
// kernel
                                               cell_size);
in your case it would be :
  points.erase(CGAL::grid_simplify_point_set(points.begin(), points.end(),                                CGAL::First_of_pair_property_map<PointVectorPair>(), cell_size), points.end());
  std::vector<Point>(points).swap(points);
Hope this helped!
Cheers,
Nad.
Nader SALMAN
Geometrica Lab, Byron Y308
INRIA Sophia Antipolis (FRANCE)
Tel: +33(0)4 9238 7161   Fax: +33(0)4 9715 5395
http://www-sop.inria.fr/members/Nader.Salman
tina rumi a écrit :
Hi all,
I am trying to use following function:
points.erase(CGAL::grid_simplify_point_set(points.begin(), points.end(), cell_size),
               points.end());
the type that I am using for points is :
// types
std::list<PointVectorPair> points;
but it caused error. I want to keep this type for points. Do you have any suggestion to fix it.
Thank you,
Tina
Ce courrier électronique et toutes les pièces éventuellement jointes qu’il
contient sont CONFIDENTIELS et destinés exclusivement à l’usage de leur
destinataire. Si une erreur de transmission ou une adresse erronée a mal
dirigée ce courrier, merci d’en informer l’expéditeur en lui faisant une
réponse par courrier électronique dès réception. Si vous n’êtes pas le
destinataire de ce courrier, vous ne devez pas l’utiliser, le conserver, en
faire état, le distribuer, le copier, l’imprimer ou en révéler le contenu à
une tierce partie.
Ce courrier électronique est à usage strictement informatif et ne saurait
engager de quelque manière que ce soit INFOTERRA France SAS, ni ses filiales.
This e-mail and any attachments hereto are CONFIDENTIAL and intended solely
for the use of the addressee. If you have received this e-mail in error
please send it back to the person that sent it to you.
If you have received it in error, please notify the sender by return email.
If you are not the addressee of this email, you must not use, keep,
disseminate, copy, print or otherwise deal with it.
This email is for information only and will not bind INFOTERRA France SAS in
any contract or obligation, nor its subsidiaries.
