Hi Laurent,
i read Tina's code but culdn't answer yesterday.
Here are the quick remarks:
#include <CGAL/property_map.h>
#include <CGAL/IO/read_xyz_points.h>
#include <CGAL/grid_simplify_point_set.h>
#include <vector>
#include <fstream>
#include <utility> // defines std::pair
#include <list> // IMPORTANT : This
method modifies the order of input
// points so as to pack all remaining points
first,
// and returns an iterator over the first
point to remove
// (see erase-remove idiom). For this reason
it should not
// be called on sorted containers.
// types
// kernel
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
// Simple geometric types
typedef Kernel::FT FT;
typedef Kernel::Point_3 Point;
typedef Kernel::Vector_3 Vector;
// Point with normal vector stored in a std::pair.
typedef std::pair<Point, Vector> PointVectorPair;
typedef std::vector<PointVectorPair> PointList;
int main(void)
PointList points; // Type of input point set
// Reads a .xyz point set file in points[].
// The Dereference_property_map property map can be omitted here as
it is the default value.
Bug std::list<PointVectorPair>
points; // Check important notice higher and
redefinition here...
std::ifstream stream("../data/kitten.xyz");
Bug CGAL::read_xyz_points// if you want to read the normals you should use the
correct function
if (!stream ||
!CGAL::read_xyz_points_and_normals(stream,
std::back_inserter(points),
CGAL::First_of_pair_property_map<PointVectorPair>(),
CGAL::Second_of_pair_property_map<PointVectorPair>()))
std::cerr << "Error: cannot read file data" <<
std::endl;
return EXIT_FAILURE;
// simplification by clustering using
erase-remove idiom
double cell_size = 0.001;
PointList::iterator unwanted_points_begin =
CGAL::grid_simplify_point_set(points.begin(), points.end(),
cell_size);
// delete unwanted points
points.erase(unwanted_points_begin , points.end());
// Optional: after erase(), use Scott
Meyer's "swap trick" to trim excess capacity
PointList(points).swap(points);
// Saves point set.
// Note: write_xyz_points_and_normals() requires an output
iterator
// over points as well as property maps to access each
// point position and normal.
std::ofstream out("out_normal.xyz");
if (!out ||
!CGAL::write_xyz_points_and_normals(
out, points.begin(), points.end(),
return EXIT_SUCCESS;
Cheers,
Nader S.
Laurent Saboret a écrit :
Hi Tina,
Could you please post your complete code, so we can try to reproduce
the compilation error below.
Best regards,
Laurent Saboret
tina rumi wrote:
Hi Nad,
Thanks a lot for your help. I am getting another error when I am
running your code. here is the error that I got:
1>Compiling...
1>cloud_points.cpp
1>c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(61) :
error C2039: 'x' : is not a member of 'std::pair<_Ty1,_Ty2>'
1> with
1> [
1> _Ty1=Point,
1> _Ty2=Vector
1> ]
1>
c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(59) : while
compiling class template member function 'bool
CGAL::CGALi::Less_epsilon_points_3<Point_3>::operator ()(const
Point_3 &,const Point_3 &) const'
1> with
1> [
1> Point_3=Enriched_point
1> ]
1> c:\program files (x86)\microsoft visual studio
9.0\vc\include\set(48) : see reference to class template instantiation
'CGAL::CGALi::Less_epsilon_points_3<Point_3>' being compiled
1> with
1> [
1> ]
9.0\vc\include\xtree(22) : see reference to class template
instantiation 'std::_Tset_traits<_Kty,_Pr,_Alloc,_Mfl>' being
compiled
1> with
1> [
1> _Kty=Enriched_point,
1>
_Pr=CGAL::CGALi::Less_epsilon_points_3<Enriched_point>,
1> _Alloc=std::allocator<PointVectorPair>,
1> _Mfl=false
1> ]
9.0\vc\include\xtree(63) : see reference to class template
instantiation 'std::_Tree_nod<_Traits>' being compiled
1> with
1> [
1>
_Traits=std::_Tset_traits<Enriched_point,CGAL::CGALi::Less_epsilon_points_3<Enriched_point>,std::allocator<PointVectorPair>,false>
1> ]
9.0\vc\include\xtree(89) : see reference to class template
instantiation 'std::_Tree_ptr<_Traits>' being compiled
1> with
1> [
1>
1> ]
9.0\vc\include\xtree(107) : see reference to class template
instantiation 'std::_Tree_val<_Traits>' being compiled
1> with
1> [
1>
1> ]
9.0\vc\include\set(57) : see reference to class template instantiation
'std::_Tree<_Traits>' being compiled
1> with
1> [
1>
1> ]
1>
c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(99) : see
reference to class template instantiation 'std::set<_Kty,_Pr>'
being compiled
1> with
1> [
1>
1> ]
1>
c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(154) : see
'CGAL::Epsilon_point_set_3<Point_3>' being compiled
1> with
1> [
1> ]
1>
c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(190) : see
reference to function template instantiation 'ForwardIterator
CGAL::grid_simplify_point_set<ForwardIterator,PointPMap,CGAL::Filtered_kernel<CK>>(ForwardIterator,ForwardIterator,PointPMap,double,const
Kernel &)' being compiled
1> with
1> [
1>
ForwardIterator=std::_Vector_iterator<PointVectorPair,std::allocator<PointVectorPair>>,
1>
PointPMap=CGAL::First_of_pair_property_map<PointVectorPair>,
1> CK=CGAL::Simple_cartesian<double>,
1>
Kernel=CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>>
1> ]
1>
f:\fingerprint\codes\cloud_points\cloud_points\cloud_points.cpp(203) :
see reference to function template instantiation 'ForwardIterator
CGAL::grid_simplify_point_set<std::_Vector_iterator<_Ty,_Alloc>,CGAL::First_of_pair_property_map<Pair>>(ForwardIterator,ForwardIterator,PointPMap,double)'
being compiled
1> with
1> [
1>
1> _Ty=PointVectorPair,
1> Pair=PointVectorPair,
1>
1> ]
1>c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(62) :
error C2039: 'y' : is not a member of 'std::pair<_Ty1,_Ty2>'
1> with
1> [
1> _Ty1=Point,
1> _Ty2=Vector
1> ]
1>c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(63) :
error C2039: 'z' : is not a member of 'std::pair<_Ty1,_Ty2>'
1> with
1> [
1> _Ty1=Point,
1> _Ty2=Vector
1> ]
error C2661: 'std::pair<_Ty1,_Ty2>::pair' : no overloaded
function takes 3 arguments
1> with
1> [
1> _Ty1=Point,
1> _Ty2=Vector
1> ]
1>c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(64) :
1> with
1> [
1> _Ty1=Point,
1> _Ty2=Vector
1> ]
1>c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(65) :
1> with
1> [
1> _Ty1=Point,
1> _Ty2=Vector
1> ]
1>c:\cgal\cgal-3.5\include\cgal\grid_simplify_point_set.h(66) :
1> with
1> [
1> _Ty1=Point,
1> _Ty2=Vector
1> ]
1> with
1> [
1> _Ty1=Point,
1> _Ty2=Vector
1> ]
1>Build log was saved at
"file://f:\fingerprint\codes\cloud_points\cloud_points\Debug\BuildLog.htm"
1>cloud_points - 8 error(s), 0 warning(s)
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
Thank you,
Tina
On Tue, Dec 8, 2009 at 12:57 PM, Nader
SALMAN <>
wrote:
A correction , here you go
// kernel
Kernel;
std::pair.
PointList points // Type of input
point
set
erase-remove idiom
points.end(),
CGAL::First_of_pair_property_map<PointVectorPair>(), cell_size);
Meyer's
Sorry for the earlier message,
Cheers,
Nad.
Nader SALMAN
Nader SALMAN a écrit :
Hi Tina,
thank you for your interest in CGAl and for using the PSP package.
here is how you should do it in general :
// kernel
Kernel;
std::pair.
cell_size);
in your case it would be :
erase-remove idiom
points.erase(CGAL::grid_simplify_point_set(points.begin(),
points.end(),
CGAL::First_of_pair_property_map<PointVectorPair>(), cell_size),
points.end());
Meyer's
std::vector<Point>(points).swap(points);
Hope this helped!
Cheers,
Nad.
Nader SALMAN
Geometrica Lab, Byron Y308
INRIA Sophia Antipolis (FRANCE)
Tel: +33(0)4 9238 7161 Fax: +33(0)4 9715 5395
http://www-sop.inria.fr/members/Nader.Salman
tina rumi a écrit :
Hi all,
I am trying to use following function:
points.end(), cell_size),
points.end());
the type that I am using for points is :
// types
std::list<PointVectorPair> points;
but it caused error. I want to keep this type for points. Do you have
any suggestion to fix it.
Thank you,
Tina
Ce courrier électronique et toutes les pièces éventuellement jointes qu’il contient sont CONFIDENTIELS et destinés exclusivement à l’usage de leur destinataire. Si une erreur de transmission ou une adresse erronée a mal dirigée ce courrier, merci d’en informer l’expéditeur en lui faisant une réponse par courrier électronique dès réception. Si vous n’êtes pas le destinataire de ce courrier, vous ne devez pas l’utiliser, le conserver, en faire état, le distribuer, le copier, l’imprimer ou en révéler le contenu à une tierce partie.
Ce courrier électronique est à usage strictement informatif et ne saurait engager de quelque manière que ce soit INFOTERRA France SAS, ni ses filiales.
This e-mail and any attachments hereto are CONFIDENTIAL and intended solely for the use of the addressee. If you have received this e-mail in error please send it back to the person that sent it to you.
If you have received it in error, please notify the sender by return email. If you are not the addressee of this email, you must not use, keep, disseminate, copy, print or otherwise deal with it.
This email is for information only and will not bind INFOTERRA France SAS in any contract or obligation, nor its subsidiaries.
