cgal-discuss - Re: [cgal-discuss] error in using CGAL::grid_simplify_point_set
  • To:
  • Subject: Re: [cgal-discuss] error in using CGAL::grid_simplify_point_set
  • Date: Tue, 08 Dec 2009 18:57:12 +0100
A correction , here you go :
// kernel
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
// Simple geometric types
typedef Kernel::FT FT;
typedef Kernel::Point_3 Point;
typedef Kernel::Vector_3 Vector;
// Point with normal vector stored in a std::pair.
typedef std::pair<Point, Vector> PointVectorPair;
typedef std::vector<PointVectorPair> PointList;
PointList points // Type of input point set
// simplification by clustering using erase-remove idiom
double cell_size = 0.001;
PointList::iterator unwanted_points_begin = CGAL::grid_simplify_point_set(points.begin(), points.end(), CGAL::First_of_pair_property_map<PointVectorPair>(), cell_size);
// delete unwanted points
points.erase(
unwanted_points_begin , points.end());
// Optional: after erase(), use Scott Meyer's "swap trick" to trim excess capacity
PointList(points).swap(points);
Sorry for the earlier message,
Cheers,
Nad.
Nader SALMAN
Nader SALMAN a écrit :
Hi Tina,
thank you for your interest in CGAl and for using the PSP package.
here is how you should do it in general :
// kernel
                                               cell_size);
in your case it would be :
  points.erase(CGAL::grid_simplify_point_set(points.begin(), points.end(),                                CGAL::First_of_pair_property_map<PointVectorPair>(), cell_size), points.end());
  std::vector<Point>(points).swap(points);
Hope this helped!
Cheers,
Nad.
Nader SALMAN
Geometrica Lab, Byron Y308
INRIA Sophia Antipolis (FRANCE)
Tel: +33(0)4 9238 7161   Fax: +33(0)4 9715 5395
http://www-sop.inria.fr/members/Nader.Salman
tina rumi a écrit :
Hi all,
I am trying to use following function:
points.erase(CGAL::grid_simplify_point_set(points.begin(), points.end(), cell_size),
               points.end());
the type that I am using for points is :
// types
std::list<PointVectorPair> points;
but it caused error. I want to keep this type for points. Do you have any suggestion to fix it.
Thank you,
Tina
