- To:
- Subject: Re: [cgal-discuss] run program cgal by vc8
- Date: Thu, 17 Dec 2009 05:01:34 -0800 (PST)
bar_ma wrote:
> Just for try:
> change C/C++ -> code generation -> Runtime library to Multi-threaded DLL
> (/MD) or try to run with every item form combobox.
I came across a similar problem.When I tried your method, it didn't work.
View this message in context:
http://n4.nabble.com/run-program-cgal-by-vc8-tp953343p965957.html
- Re: [cgal-discuss] run program cgal by vc8, variable, 12/17/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] run program cgal by vc8, variable, 12/18/2009
- Re: [cgal-discuss] run program cgal by vc8, Laurent Rineau (GeometryFactory), 12/18/2009
- Re: [cgal-discuss] run program cgal by vc8, variable, 12/21/2009
