- To:
- Subject: Re: [cgal-discuss] run program cgal by vc8
- Date: Fri, 18 Dec 2009 14:31:53 +0100
On Friday 18 December 2009 14:12:10 variable wrote:
> It works, but what is weird is the words in the manual page(installation
> manual:
> http://www.cgal.org/Manual/3.4/doc_html/installation_manual/Chapter_install
> ation_manual.html#Footnote_12 )4.6 Static vs.Dynamic Libraries:Under
> windows we only support the static versions of the CGAL libraries...
There is a confusion between static/dynamic library (/DLL or not), and
static/dynamic C/C++ runtime (/MD or /MT)!
As far as I understand, CGAL under Windows creates static CGAL libraries
using
dynamic runtime (/MD).
Laurent Rineau, PhD
- Re: [cgal-discuss] run program cgal by vc8, variable, 12/17/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] run program cgal by vc8, variable, 12/18/2009
- Re: [cgal-discuss] run program cgal by vc8, Laurent Rineau (GeometryFactory), 12/18/2009
- Re: [cgal-discuss] run program cgal by vc8, variable, 12/21/2009
