cgal-discuss - Re: [cgal-discuss] run program cgal by vc8
  • To:
  • Subject: Re: [cgal-discuss] run program cgal by vc8
  • Date: Sun, 20 Dec 2009 22:59:45 -0800 (PST)
Laurent Rineau (GeometryFactory) wrote:
> On Friday 18 December 2009 14:12:10 variable wrote:
>> It works, but what is weird is the words in the manual page(installation
>> manual:
>> http://www.cgal.org/Manual/3.4/doc_html/installation_manual/Chapter_install
>> ation_manual.html#Footnote_12 )4.6 Static vs.Dynamic Libraries:Under
>> windows we only support the static versions of the CGAL libraries...
> There is a confusion between static/dynamic library (/DLL or not), and
> static/dynamic C/C++ runtime (/MD or /MT)!
> As far as I understand, CGAL under Windows creates static CGAL libraries
> using
> dynamic runtime (/MD).
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
I was wrong last time, I thought it was compile variants I chose that made
the problem(
LDR: LdrpWalkImportDescriptor() failed to probe
C:\CGAL-3.4\auxiliary\gmp\lib\gmp-vc80-mt-gd.dll for its manifest, ntstatus
0xc0150002)
happen, but de facto is I didn't install sp1 for VS2005, after installing
that, everything is ok now.
See
http://social.msdn.microsoft.com/Forums/zh-CN/vcgeneral/thread/3f2869ca-2c07-49a8-a443-52720b10ea09
Obviously, CGAL is built on VS2005 SP1, I guess if it would be better to be
explicitly marked on the installation manual.
View this message in context:
http://n4.nabble.com/run-program-cgal-by-vc8-tp953343p976059.html
