- To:
- Subject: Re: [cgal-discuss] a question about setup cgal3.5.1.exe
- Date: Wed, 6 Jan 2010 14:22:15 +0100
On Wednesday 06 January 2010 14:07:55 mycug wrote:
> dear Laurent,
> Recently i download a cgal3.5.1. After I execute "CGAL-3.5.1-Setup.exe" int
> the default position, it cannot create the proj file of vc8.0. why?
Unless I am wrong, you have not read the installation manual of CGAL:
http://www.cgal.org/Manual/3.5/doc_html/installation_manual/contents.html
It says that, once you have installed CGAL using the Windows installer, you
need to install CMake, call cmake-gui.exe, and configure it so that it can
create a MSVC solution to compile CGAL libraries (and examples and demos).
Laurent Rineau, PhD
- [cgal-discuss] after install cgal MSVC 2005 : application failed to start, Maarten Moesen, 01/05/2010
- Re: [cgal-discuss] after install cgal MSVC 2005 : application failed to start, Laurent Rineau (GeometryFactory), 01/05/2010
- Re: [cgal-discuss] after install cgal MSVC 2005 : application failed to start, Maarten Moesen, 01/05/2010
- Re: [cgal-discuss] after install cgal MSVC 2005 : application failed to start, Laurent Rineau (GeometryFactory), 01/06/2010
- [cgal-discuss] a question about setup cgal3.5.1.exe, mycug, 01/06/2010
- Re: [cgal-discuss] a question about setup cgal3.5.1.exe, Laurent Rineau (GeometryFactory), 01/06/2010
- Re: [cgal-discuss] after install cgal MSVC 2005 : application failed to start, Maarten Moesen, 01/07/2010
