cgal-discuss - Re: [cgal-discuss] after install cgal MSVC 2005 : application failed to start
  • To: "" <>
  • Subject: Re: [cgal-discuss] after install cgal MSVC 2005 : application failed to start
  • Date: Thu, 7 Jan 2010 16:11:15 +0100
Dear Laurent,
It turned out that for some reason SP1 did not properly install the new MVSCR80.DLL and MVSCP80.DLL to the right directory. Putting them there solved the 'application failed to start' issue.
Thank you very much for your sharp advice :)
Best regards,
Maarten Moesen
On Tuesday 05 January 2010 20:17:46 Maarten Moesen wrote:
Dear Laurent,
Thank you for your quick reply!
We indeed confirmed that the MSVCP80.DLL is pre-SP1.
We'll try reinstalling SP1 (or the VS2005 redistributable).
Any suggestion how to fix this is surely welcome ;)
Verify that your MSVS has the last patches. Then, make sure that last vcredist
for last VC80 is install. As I am not really a user of Windows products, I
cannot give you more information about the precise way to proceed.
Or upgrade to VC90! ;-) VC10 is about to be released (beta stage for now).
Laurent Rineau, PhD
Maarten Moesen, PHD
Department of Metallurgy and Materials Engineering (MTM)
K.U.Leuven
Kasteelpark Arenberg 44 - Bus 02450
B-3001 Heverlee, Belgium
tel. +32 (0)16 32 13 17
fax. +32 (0)16 32 19 90
