Re: [cgal-discuss] dgelss cannot be found CGAL3.5 OSX10.6.2 gcc4.2.1 cmake2.6 taucs
- To:
- Subject: Re: [cgal-discuss] dgelss cannot be found CGAL3.5 OSX10.6.2 gcc4.2.1 cmake2.6 taucs
- Date: Thu, 28 Jan 2010 16:01:27 +0100
Thanks for your help, Here is a screenshot of my folder : C:\Program Files\CGAL-3.5.1\auxiliary\taucs\lib ![]() Here is the output of CMake in the folder : C:\Program Files\CGAL-3.5.1\examples\Point_set_processing_3 : Build type: Release USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR -D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE -D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_WARNINGS /fp:strict /fp:except- /MD /O2 /Ob2 /D NDEBUG' USING EXEFLAGS = ' /STACK:10000000 /machine:I386 /INCREMENTAL:NO' Targetting Visual Studio 9 2008 Target build enviroment supports auto-linking Using VC90 compiler. Generator uses intermediate configuration directory: $(OutDir) USING DEBUG CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHa /GR -D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE -D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_WARNINGS /fp:strict /fp:except- /FR /wd4267 /wd4311 /wd4800 /wd4503 /wd4244 /wd4345 /wd4996 /wd4396 /wd4018 /D_DEBUG /MDd /Zi /Ob0 /Od /RTC1' USING DEBUG EXEFLAGS = ' /STACK:10000000 /machine:I386 /LARGEADDRESSAWARE /debug /INCREMENTAL:YES' USING RELEASE CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHa /GR -D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE -D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_WARNINGS /fp:strict /fp:except- /FR /wd4267 /wd4311 /wd4800 /wd4503 /wd4244 /wd4345 /wd4996 /wd4396 /wd4018 /MD /O2 /Ob2 /D NDEBUG' USING RELEASE EXEFLAGS = ' /STACK:10000000 /machine:I386 /LARGEADDRESSAWARE /INCREMENTAL:NO' LAPACK include: C:/Program Files/CGAL-3.5.1/auxiliary/taucs/include LAPACK definitions: LAPACK library directories: C:/Program Files/CGAL-3.5.1/auxiliary/taucs/lib LAPACK link flags: BLAS include: C:/Program Files/CGAL-3.5.1/auxiliary/taucs/include BLAS definitions: BLAS library directories: C:/Program Files/CGAL-3.5.1/auxiliary/taucs/lib BLAS link flags: Configuring done Generating done Laurent Saboret a écrit : Hi Thibault, |
- Re: Re: [cgal-discuss] dgelss cannot be found CGAL3.5 OSX10.6.2 gcc4.2.1 cmake2.6 taucs, thibault.luginbuhl, 01/26/2010
- Re: [cgal-discuss] dgelss cannot be found CGAL3.5 OSX10.6.2 gcc4.2.1 cmake2.6 taucs, Laurent Saboret, 01/27/2010
- Re: [cgal-discuss] dgelss cannot be found CGAL3.5 OSX10.6.2 gcc4.2.1 cmake2.6 taucs, Thibault LUGINBÜHL, 01/28/2010
- Re: [cgal-discuss] dgelss cannot be found CGAL3.5 OSX10.6.2 gcc4.2.1 cmake2.6 taucs, Laurent Saboret, 01/28/2010
- Re: [cgal-discuss] dgelss cannot be found CGAL3.5 OSX10.6.2 gcc4.2.1 cmake2.6 taucs, Laurent Saboret, 01/29/2010
