cgal-discuss - Re: [cgal-discuss] dgelss cannot be found CGAL3.5 OSX10.6.2 gcc4.2.1 cmake2.6 taucs
  • To:
  • Subject: Re: [cgal-discuss] dgelss cannot be found CGAL3.5 OSX10.6.2 gcc4.2.1 cmake2.6 taucs
  • Date: Thu, 28 Jan 2010 17:10:35 +0100
Hi,
Here is the output of the compiler with the definition you asked :
1>Deleting intermediate and output files for project 'jet_smoothing_example', configuration 'Release|Win32'
1>Building Custom Rule C:/Program Files/CGAL-3.5.1/examples/Point_set_processing_3/CMakeLists.txt
1>CMake does not need to re-run because CMakeFiles/generate.stamp is up-to-date.
1>Compiling...
1>jet_smoothing_example.cpp
1>Linking to lib file: CGAL-vc90-mt.lib
1>Linking to lib file: gmp-vc90-mt.lib
1>Linking to lib file: mpfr-vc90-mt.lib
1>Linking to lib file: liblapack.lib
1>Linking to lib file: libf77blas.lib
1>Linking to lib file: libcblas.lib
1>Linking to lib file: libatlas.lib
1>Linking to lib file: vcf2c-vc90-mt.lib
1>Linking...
1>jet_smoothing_example.obj : error LNK2019: unresolved external symbol _dgelss_ referenced in function "void __cdecl CGAL::LAPACK::dgelss(int *,int *,int *,double *,int *,double *,int *,double *,double *,int *,double *,int *,int *)" (?dgelss@LAPACK@CGAL@@YAXPAH00PAN010110100@Z)
1>C:\Program Files\CGAL-3.5.1\examples\Point_set_processing_3\Release\jet_smoothing_example.exe : fatal error LNK1120: 1 unresolved externals
1>Creating browse information file...
1>Microsoft Browse Information Maintenance Utility Version 9.00.30729
1>Copyright (C) Microsoft Corporation. All rights reserved.
1>Build log was saved at "file://c:\Program Files\CGAL-3.5.1\examples\Point_set_processing_3\jet_smoothing_example.dir\Release\BuildLog.htm"
1>jet_smoothing_example - 2 error(s), 0 warning(s)
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
Regards,
Thibault LUGINBÜHL
Laurent Saboret a écrit :
Hi Thibault,
LAPACK seems properly installed on your machine and CMake detects it.
On Windows, LAPACK is added to link step via a feature called auto-linking.
Please add
#define CGAL_LIB_DIAGNOSTIC
at the beginning of e.g. jet_smoothing_example.cpp, compile it and post the compiler's output.
Regards,
Laurent Saboret
Thibault LUGINBÜHL wrote:
Thanks for your help,
Here is a screenshot of my folder : C:\Program Files\CGAL-3.5.1\auxiliary\taucs\lib
taucsDirectorty
Here is the output of CMake in the folder : C:\Program Files\CGAL-3.5.1\examples\Point_set_processing_3 :
Build type: Release
USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR -D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE -D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_WARNINGS /fp:strict /fp:except- /MD /O2 /Ob2 /D NDEBUG'
USING EXEFLAGS = ' /STACK:10000000 /machine:I386 /INCREMENTAL:NO'
Targetting Visual Studio 9 2008
Target build enviroment supports auto-linking
Using VC90 compiler.
Generator uses intermediate configuration directory: $(OutDir)
USING DEBUG CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHa /GR -D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE -D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_WARNINGS /fp:strict /fp:except- /FR /wd4267 /wd4311 /wd4800 /wd4503 /wd4244 /wd4345 /wd4996 /wd4396 /wd4018 /D_DEBUG /MDd /Zi /Ob0 /Od /RTC1'
USING DEBUG EXEFLAGS = ' /STACK:10000000 /machine:I386 /LARGEADDRESSAWARE /debug /INCREMENTAL:YES'
USING RELEASE CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHa /GR -D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE -D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_WARNINGS /fp:strict /fp:except- /FR /wd4267 /wd4311 /wd4800 /wd4503 /wd4244 /wd4345 /wd4996 /wd4396 /wd4018 /MD /O2 /Ob2 /D NDEBUG'
USING RELEASE EXEFLAGS = ' /STACK:10000000 /machine:I386 /LARGEADDRESSAWARE /INCREMENTAL:NO'
LAPACK include: C:/Program Files/CGAL-3.5.1/auxiliary/taucs/include
LAPACK definitions:
LAPACK library directories: C:/Program Files/CGAL-3.5.1/auxiliary/taucs/lib
LAPACK link flags:
BLAS include: C:/Program Files/CGAL-3.5.1/auxiliary/taucs/include
BLAS definitions:
BLAS library directories: C:/Program Files/CGAL-3.5.1/auxiliary/taucs/lib
BLAS link flags:
Configuring done
Generating done
Hi Thibault,
On Windows, CGAL searches for LAPACK in P:/ath/to/TAUCS/auxiliary/taucs.
Please post the content of this folder on your PC.
LAPACK should be detected at CMake stage.
Please run again CMake in e.g.  jet_smoothing_example's folder and post its output
(I recommend you do use cmake-gui to see CMake's output).
Best regards,
Laurent Saboret
Hi Laurent,
Thanks for your answer, but I checked it.
I have lapack.lib in the taucs directory, I even tried to manually add the directory and the name of the lib in the options of visual studio, but the problem remains the same.
I also tried to download the latest version of clapack, compiled it and tried to use this one but nothing changed.
The exact same error appears in different examples : jet_smoothing_example, single_estimation, mesh_estimation, Compute_Ridges_Umbilics.
The error is :
Regards,
Thibault LUGINBÜHL
Hi Thibault,
You need the LAPACK library to compile the normal estimation example.
To install it:
Run CGAL 3.5.1 Windows installer, select your platform and compiler, and check the option to install LAPACK, BLAS and TAUCS libraries.
Then follow the instructions to compile CGAL.
Best regards,
Laurent Saboret
wrote:
Hi,
I have the same problem but on winXP with VS2008.
I used cmake2.6 to generate all examples en demos. But the projects using
lapack failed at the linking. I have the same message : CGAL::LAPACK::dgelss
couldn't be found. (I try to compile the normal estimation project in the point
set processing package)
I don't have the same options in cmake as you have on OSX10.6.2 apparently.
Does anyone knows how to make it work under this configuration XP SP2 32bit,
VS2008 ?
Thanks in advance,
Thibault LUGINBÜHL
Ce courrier électronique et toutes les pièces éventuellement jointes qu’il contient sont CONFIDENTIELS et destinés exclusivement à l’usage de leur destinataire. Si une erreur de transmission ou une adresse erronée a mal dirigée ce courrier, merci d’en informer l’expéditeur en lui faisant une réponse par courrier électronique dès réception. Si vous n’êtes pas le destinataire de ce courrier, vous ne devez pas l’utiliser, le conserver, en faire état, le distribuer, le copier, l’imprimer ou en révéler le contenu à une tierce partie.
Ce courrier électronique est à usage strictement informatif et ne saurait engager de quelque manière que ce soit INFOTERRA France SAS, ni ses filiales.
This e-mail and any attachments hereto are CONFIDENTIAL and intended solely for the use of the addressee. If you have received this e-mail in error please send it back to the person that sent it to you.
If you have received it in error, please notify the sender by return email. If you are not the addressee of this email, you must not use, keep, disseminate, copy, print or otherwise deal with it.
This email is for information only and will not bind INFOTERRA France SAS in any contract or obligation, nor its subsidiaries.
