- To:
- Subject: Re: [cgal-discuss] Precondition Violation in Mesh Refinement 2 Package
- Date: Tue, 23 Mar 2010 12:33:29 +0100
On Tuesday 23 March 2010 11:04:35 Simon Perkins wrote:
> Hi Laurent
> I've added the assertion but the problem still occurs. Here is the code. It
> produces the two different precondition errors on both CGAL 3.5.1 and 3.6.
> The call to refine_Delaunay_mesh_2 is on line 62 of trigen.cpp.
Congratulation! You have found a bug in Mesh_2! Your data set is quite
strange, because you insert in a cdt all finite edges of another one. That
uncommon data set triggers a bug in the detection of clusters of constrained
edges.
I will send you a fix of include/CGAL/Mesh_2/Clusters.h before the end of the
week.
Do you agree that your (random) data set is inserted in the CGAL test suite?
Being uncommon, it is interesting!
Laurent Rineau, PhD
- [cgal-discuss] Precondition Violation in Mesh Refinement 2 Package, Simon Perkins, 03/09/2010
- [cgal-discuss] Re: Precondition Violation in Mesh Refinement 2 Package, Simon Perkins, 03/16/2010
- Re: [cgal-discuss] Precondition Violation in Mesh Refinement 2 Package, Laurent Rineau (GeometryFactory), 03/16/2010
- Re: [cgal-discuss] Precondition Violation in Mesh Refinement 2 Package, Simon Perkins, 03/23/2010
- Re: [cgal-discuss] Precondition Violation in Mesh Refinement 2 Package, Laurent Rineau (GeometryFactory), 03/23/2010
- Re: [cgal-discuss] Precondition Violation in Mesh Refinement 2 Package, Simon Perkins, 03/25/2010
