cgal-discuss - Re: [cgal-discuss] Re: is fast location for periodic Delaunay broken?
  • To:
  • Subject: Re: [cgal-discuss] Re: is fast location for periodic Delaunay broken?
  • Date: Thu, 29 Apr 2010 13:25:42 +0200
Dear Ariel Keselman,
On 29/04/10 11:51, Ariel Keselman wrote:
Well.. not exactly solved. It compiles, but doesn't run-
program gets stuck at the first insert(begin,end,true);
What exactly does it mean "get stuck"?
Please compile in "Debug" mode and run it again and tell us what happens (i.e. which assertion is thrown or what other behavior it shows).
this is how I defined the triangulation, I need a vertex
with info:
This looks ok.
best
Manuel
typedef CGAL::Exact_predicates_inexact_constructions_kernel TKernel;
typedef CGAL::Periodic_3_triangulation_traits_3<TKernel> TTraits;
typedef CGAL::Periodic_3_triangulation_ds_vertex_base_3<> TdVBase;
typedef CGAL::Triangulation_vertex_base_3<TTraits,TdVBase> TVBase;
typedef CGAL::Periodic_3_triangulation_ds_cell_base_3<> TdCBase;
typedef CGAL::Triangulation_cell_base_3<TTraits,TdCBase> TCBase;
typedef CGAL::Triangulation_vertex_base_with_info_3<tvi,TTraits,TVBase>
TiVBase_s;
typedef CGAL::Triangulation_hierarchy_vertex_base_3<TiVBase_s> TiVBase; ///
typedef CGAL::Triangulation_data_structure_3<TiVBase, TCBase> TDS;
typedef CGAL::Periodic_3_Delaunay_triangulation_3<TTraits, TDS> TPDT_s;
typedef CGAL::Periodic_3_triangulation_hierarchy_3<TPDT_s> PDT;
