- To:
- Subject: Re: [cgal-discuss] Re: is fast location for periodic Delaunay broken?
- Date: Thu, 29 Apr 2010 19:40:26 +0200
Hi Ariel,
did it finally work? Please let me know, I am very interested in finding the cause of the problem and maybe the bug if there is some.
Thank you
Manuel
On 29/04/10 15:15, Ariel Keselman wrote:
the point set I attached before was not shuffled, and the problem there
appears a bit later.
please
http://n4.nabble.com/forum/FileDownload.jtp?type=n&id=2075433&name=points.xyz
points.xyz use this file.
- [cgal-discuss] Re: is fast location for periodic Delaunay broken?, (continued)
- [cgal-discuss] Re: is fast location for periodic Delaunay broken?, Ariel Keselman, 04/29/2010
- Re: [cgal-discuss] Re: is fast location for periodic Delaunay broken?, Manuel Caroli, 04/29/2010
