cgal-discuss - [cgal-discuss] Re: is fast location for periodic Delaunay broken?
  • To:
  • Subject: [cgal-discuss] Re: is fast location for periodic Delaunay broken?
  • Date: Thu, 29 Apr 2010 05:03:08 -0700 (PDT)
OK, I run it with -DNDEBUG, and got this:
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: (_domain.xmin() <= p.x()) && (p.x() < _domain.xmax())
File:
/home/kari/Desktop/damage/cgal/include/CGAL/Periodic_3_triangulation_3.h
Line: 2218
RUN FAILED (exit value 134, total time: 28s)
However, I am inserting every point by itself, and checking that all of them
are
indeed inside the domain... the assertion fails only after about 700
particles.
Also, this assertion does not fail when using the non-hierarchal Delaunay
tessellation.
I think there could be a problem in the library- maybe this happens when a
27 sheet
tessellation goes into a single sheeted one?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/is-fast-location-for-periodic-Delaunay-broken-tp2075170p2075349.html
