cgal-discuss - Res: Res: Res: [cgal-discuss] Create CMakeListis.txt
  • To:
  • Subject: Res: Res: Res: [cgal-discuss] Create CMakeListis.txt
  • Date: Tue, 18 May 2010 05:06:37 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com.br; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=WiRvJtHb+IEIixAEanbi3iiERt3JypKFt8mZ46n9lY7OUFh2V9M95KTPDFUugEB/8csfTZNWeOrTlMlZGC0Gqo9MGdlVbi7G6M6hYz4wpoxIdg1ykfY4QYXQWrAK6xxoQ7lC/PaRpEy2t0gLN3NY12znahxB4mO9gwNFgFFAle8=;
I used the command 'cgal_create_cmake_script demo' with the example 'Convex_hull_2' and the CMakeLists.txt was generated right.
 But when I try with the example 'GraphicsView' (min.cpp) the CMakeLists.txt was generated wrong. I try with the command cmake-gui too.
Anybody can help me?
thanks
Rogerio
De: Rogério Pozza <>
Para:
Enviadas: Domingo, 16 de Maio de 2010 11:18:54
Assunto: Res: Res: [cgal-discuss] Create CMakeListis.txt
This is the original CMakeLists.txt
# This is the CMake script for compiling a CGAL application.
project (GraphicsView)
cmake_minimum_required(VERSION 2.4)
set(CMAKE_ALLOW_LOOSE_LOOP_CONSTRUCTS true)
if ( COMMAND cmake_policy )
  cmake_policy( SET CMP0003 NEW )
endif()
find_package(CGAL COMPONENTS Qt4)
include(${CGAL_USE_FILE})
set( QT_USE_QTXML    TRUE )
set( QT_USE_QTMAIN   TRUE )
set( QT_USE_QTSCRIPT  TRUE )
set( QT_USE_QTOPENGL  TRUE )
find_package(Qt4)
if ( CGAL_FOUND AND CGAL_Qt4_FOUND AND QT4_FOUND )
  include(${QT_USE_FILE})
  add_executable  ( min min.cpp )
  add_to_cached_list( CGAL_EXECUTABLE_TARGETS min )
  # Link with Qt libraries
  target_link_libraries( min ${QT_LIBRARIES} )
  # Link with CGAL
  target_link_libraries( min ${CGAL_LIBRARIES}  ${CGAL_3RD_PARTY_LIBRARIES})
else()
  message(STATUS "NOTICE: This demo requires CGAL and Qt4, and will not be compiled.")
endif()
And this is generated by cgal_create_cmake_script demo (doesn't work)
# Created by the script cgal_create_cmake_script
project( Graphics_demo )
CMAKE_MINIMUM_REQUIRED(VERSION 2.4.5)
endif()
find_package(CGAL QUIET COMPONENTS Core Qt3 )
if ( CGAL_FOUND )
  include( ${CGAL_USE_FILE} )
  find_package(Qt3-patched QUIET )
  # FindQt3-patched.cmake is FindQt3.cmake patched by CGAL developers, so
  # that it can be used together with FindQt4: all its variables are prefixed
  # by "QT3_" instead of "QT_".
  if(CGAL_Qt3_FOUND AND QT3_FOUND)
    include( Qt3Macros-patched )
    qt3_automoc(  min.cpp )
    # Make sure the compiler can find generated .moc files
    include_directories(BEFORE ${CMAKE_CURRENT_BINARY_DIR})
    include_directories( ${QT3_INCLUDE_DIR} )
    add_executable  (Graphics_demo  min.cpp)
    add_to_cached_list( CGAL_EXECUTABLE_TARGETS Graphics_demo )
    # Link the executable to CGAL and third-party libraries
    target_link_libraries(Graphics_demo ${QT3_LIBRARIES} ${CGAL_LIBRARIES} ${CGAL_3RD_PARTY_LIBRARIES} )
  else()
    message(STATUS "NOTICE: This demo requires Qt3 and the CGAL Qt3 library, and will not be compiled.")
  endif()
else()
    message(STATUS "NOTICE: This demo requires the CGAL library, and will not be compiled.")
endif()
Para:
Enviadas: Domingo, 16 de Maio de 2010 11:13:29
Assunto: Res: [cgal-discuss] Create CMakeListis.txt
I used it but no sucess.
The program is simple:
#include <QtGui>
#include <CGAL/Qt/GraphicsViewNavigation.h>
#include <QLineF>
#include <QRectF>
int main(int argc, char **argv)
    QApplication app(argc, argv);
    QGraphicsScene scene;
    scene.setSceneRect(0,0, 100, 100);
    scene.addRect(QRectF(0,0, 100, 100));
    scene.addLine(QLineF(0,0, 100, 100));
    scene.addLine(QLineF(0,100, 100, 0));
    QGraphicsView* view = new QGraphicsView(&scene);
    CGAL::Qt::GraphicsViewNavigation navigation;
    view->installEventFilter(&navigation);
    view->viewport()->installEventFilter(&navigation);
    view->setRenderHint(QPainter::Antialiasing);
    view->show();
    return app.exec();
But the CMakeLists.txt is not right. I user cmake . and make. The errors:
Scanning dependencies of target Graphics_demo
[100%] Building CXX object CMakeFiles/Graphics_demo.dir/min.o
/tmp/Graphics/min.cpp:3:17: error: QtGui: No such file or directory
In file included from /tmp/Graphics/min.cpp:4:
/usr/include/CGAL/Qt/GraphicsViewNavigation.h:25:19: error: QObject:
/usr/include/CGAL/Qt/GraphicsViewNavigation.h:26:19: error: QPointF: No such file or directory
/usr/include/CGAL/Qt/GraphicsViewNavigation.h:27:19: error: QString: No such file or directory
/usr/include/CGAL/Qt/GraphicsViewNavigation.h:28:19: error: QCursor: No such file or directory
/usr/include/CGAL/Qt/GraphicsViewNavigation.h:29:17: error: QRect: No such file or directory
/usr/include/CGAL/Qt/GraphicsViewNavigation.h:30:18: error: QRectF: No such file or directory
/tmp/Graphics/min.cpp:5:18: error: QLineF: No such file or directory
And so on.
De: Eric Berberich <>
Para:
Enviadas: Domingo, 16 de Maio de 2010 11:00:26
Assunto: Re: [cgal-discuss] Create CMakeListis.txt
wrote:
> Hi,
> I'm writing a program with graphics interfaces (Ubuntu 10.4) and the command
> cgal_create_cmake_script creates a bad file. how can I do to create the CMakeLists.txt file?
Use "cgal_create_cmake_script demo"
eriC
-- You are currently subscribed to cgal-discuss.
